Official Yocto BUGS list
Re: Official Yocto BUGS list
Postby rv0 » Jan 27th, '17, 09:10
As I'm preparing for a live set using the yocto as a master, I'm stumbling across more bugs, will share them here:
BUG: There's some issue with Copy Paste.
Sometimes when you copy and switch to paste mode, it is impossible to select a pattern.
Best way is to select a pattern first in copy mode and then go to paste mode. That works about 75% of the time, the other 25% it seems to "crash", which usually means it defaults back to bank 1 (e.g. when you were in bank 4) and/or you have to visit pattern play first to make it behave normal again.
Also very annoying with the Copy Paste is that it doesn't seem to follow the "bank" context of Pattern Play, which is confusing as one must remember to switch to the correct bank every time.
EDIT: seems this had to do with a bad mode selector switch or solder joint, as touching the knob causes this behavior.. Hopefully it will hold till after my liveset ;)
POSSIBLE BUG: Not 100% sure as I haven't been able to reproduce it, but when copying a 32 step pattern I noticed some of my accents were missing. Could be human error though, but I mention it nonetheless.
EDIT: had this happen several times again yesterday
FEATURE REQUEST: Roll mode allows to change the rate with the encoder. But it only allows for increased rate, while 1/8ths and maybe even 1/4ths would be cool too.
rv0
Postby rat » Feb 3rd, '17, 16:20
Still hoping there is some support or at least time for the devs to upload latest firmware to github.
This suuuuucks =
- It is possible to switch from pattern play (midi) to pattern edit while playing, but when pressing stop on the external clock source, you have to switch the yocto back to pattern play, otherwise it won't start.
rat
Postby FlavioB » Feb 15th, '17, 22:21
rv0 wrote:FEATURE REQUEST: Roll mode allows to change the rate with the encoder. But it only allows for increased rate, while 1/8ths and maybe even 1/4ths would be cool too.
I'd just love to have it as on the Quicksilver 606 mod: from 1/4ths up to 1/32nds :-)
FlavioB
Postby decoder303 » Feb 24th, '17, 17:17
what about the roll function, is this fixed already somewhere? Roll doesn't work at all with my Yocto with midi sync play, as master it's working fine..
decoder303
Postby FlavioB » Jun 18th, '17, 10:27
Bump. No news here???
FlavioB
Postby rat » Jun 27th, '17, 11:56
maybe after v2 is out in the wild..but i doubt it. Maybe we can at least get a proper, latest github update for everything so it will be up to community to change the firmware.
rat
Postby FlavioB » Sep 10th, '17, 12:28
Hi ppl.
Seems to be a "dead end" here... nobody taking care of bugs, nobody doing some corrections/fixed on the code...
Did Vincent give up?
It's pretty much pissing off to have a Yocto with quite a lot of bugs that nobody is looking into.
I've been attracted by Yocto2 but I will FOR SURE not buy/build one: the experience with the Yocto firmware (and same goes for Nava firmware) has discouraged me. Sad to see all this e-licktronic thing somehow "die away"...
FlavioB
Postby rv0 » Sep 10th, '17, 21:12
Some recent developments:
forum member jvq has been working on rewriting the midi expander mode
Timing has been improved a lot, it's quite amazing.
https://gitlab.com/jacobvosmaer/yocto-firmware (Download => Artifacts => click Download Build)
I did some comparisons with a midi-heavy pattern:
stock firmware: listen
jvq version: listen
That's a giant leap forward in my workflow.
He also started a pure avr-c rewrite: https://gitlab.com/jacobvosmaer/yocto-f ... /midi-avrc (currently only does midi expander mode), perhaps he will take on the rest of the firmware after that.. It's sure nice to see this being pushed forward, open source at its best :)
rv0
Postby FlavioB » Sep 11th, '17, 07:51
Hi rv0 - thanks for your reply.
So this means that somebody (jvq) has started code re-write? Did he pick up from 1.0c (latest) version?
A friend of mine is now looking into the code as well...
FlavioB
Postby rv0 » Sep 11th, '17, 09:42
FlavioB wrote:So this means that somebody (jvq) has started code re-write?
He "fixed" Midi Expander mode in the current version and the realized he could get even better results by starting from scratch in AVR-C (without the arduino libraries)
So far he hasn't stated any roadmap for future plans, it's limited to expander mode now. but we can only hope :) In any case the code quality is very good imo.
FlavioB wrote:Did he pick up from 1.0c (latest) version?
yes, as can be seen in the commit messages and as can be read in other recent posts in this subform.
rv0
PreviousNext
Return to Yocto v1.0 Software
