I've got the kit and the mouser bom from march or so, but haven't started it yet due to other projects - i've checked in on the forum meanwhile, and have some questions that would like some input on, but I have a feeling some of them were answered before.
I look forward to your comments.
- Socketing ICs - does anyone have a bom for these handy? I'll put one together if not.
- bPower cable mod - not sure about the correct term, but I see that often people are adding internal power supplies. I am wondering if the power supply mods also improve the sound (saw it discussed i believe) and is generally a must have for the Yocto. I am not sure where to begin with making such a mod, would be cool to discuss it with someone who did it - perhaps in one of the relevant topics.
- case - is it necessary to have a case before starting the build, perhaps to make some steps easier?
- cable socketing - i feel like detachable cables might be a good idea since it is recommended to test the board as you build each instrument section - any best practice tips? I see people are using molex cables - any boms would be a nice learning step for me.
- measuring components before soldering - do you generally recommend making organized piles and measuring each component as you build a section? or is this overkill. Also, i've ordered a mouser bom from some months ago (i think march 8) - should i check it against updated boms in case some parts were missing, or is it safe to say not much changed other than component swaps due to stock. Does mouser tend to deliver the exact number of components? I guess this is something i'll find out soon.
- tuning components with oscilloscope and multimeter - I noticed the build guide suggests to test each instrument section as you build it, should I also check into the approach to trigger the instruments and tune them as I go, or just wait until the sequencer is done? Also wondering if sequencer can be built first and work without all instruments completed?
- Firmware update - haven't read up on this yet, is it best to get some equipment to reprogram the firmware before the build or it isn't that bad (i assume there is a socket for this one).
- soldering iron tips - should i get very fine tips for this job or a general one is not so bad? Did you go through more than one tip with this build?
- temperature of room when tuning instruments - does it matter what the room temperature is when you eventually have to adjust resistors?
- should you put some sort of rubber or hot glue on the adjustable resistors- i am wondering if these things have a tendency to move around in high vibration environments? would be nice to gig with these things.
- My biggest fears are design updates by users, like component replacements to improve sounds - i've seen a few but would be cool if someone who remembers them all gives me some tips. I haven't seen them compiled together in a list yet.
