big problem to use tap mode and play in real time - hi-hats Bug!!!
when you try to program any other instruments in tap mode - hi-hats triggered and played open hi-hat instead of closed or hi-hats cut!
!!!!! try to remove the volume of all instruments except the hi-hats and program them "closed"on every step from 1-16, then in tap mode, try to click on keys any other instrument (bass, snare toms ....) -> hi-hats thus react to pressing the keys of other instruments and it turns out a mess !!!
When this bug will be fixed?
that's just terrible! not impossible to work in tap mode .... I collected 2 nava and both behave the same problem - it is a problem with the firmware ...
Any have exactly the same problem?
Hi-hats bug in tap mode
I don't know what you mean? All seems to work fine with mine in tap mode now since the last FW update.
My two nava's have this problem with hi hats in tap mode:((( this is video:
https://www.mediafire.com/download/o10c1w3vmcnqb14
[/youtube]
[/youtube]
drifter7508 wrote:I don't know what you mean? All seems to work fine with mine in tap mode now since the last FW update.
I will try when i get home with mine. I didnt have this problem before. What version of the firmware are you running ?
Aarrgghh wrote:I will try when i get home with mine. I didnt have this problem before. What version of the firmware are you running ?
Last, 1.22
I just played around a bit in tap mode, and I can't say I can duplicate the problem unfortunately
I can't duplicate the problem either.
Sorry for my bad English)), I'm from Russia... you don't have this problem? did I understand you correctly? Google translate not correct)))... your navas work fine? But Vincent says obout it - this is software bug and will be solve quite soon... also in real 909 have this trabl
Grizzlydj wrote:big problem to use tap mode and play in real time - hi-hats Bug!!!
Should be solved with the Nava v1.023 update
Wow, that was quick! Thanks Vincent! I'll check out later...
Regarding C89 and C163: they are already 10nf/ 0,01uf. Is this a typing error?
