The truth is that I went crazy with this.
-Write on HH CH ...
1, 7, 11 there is 7 stronger
3, 9, 15 there is 9 stronger
To solve, install a capacitor of 470K in the IC 4011. Pin 1 & 7.
The capacitor value must be 470n - 0.47 micro. Material PolyesterAarrgghh wrote:I'll try to see if i can duplicate the problem you are describing tonight.
Do you mean a 47p %10 cap between thoose legs should solve the problems ?
Ok, I'll try out later as I am also experiencing this behaviour of the hats. Didn't notice it though before you pointed it out...eleclove wrote:The capacitor value must be 470n - 0.47 micro. Material PolyesterKlangGenerator wrote:Thanks for sharing! Guess you mean resistor, not capacitor. Would you mind to upload a foto of your mod?
IC 4011. Pin 1 & 7.
Works like a charm! Thank you!eleclove wrote:The capacitor value must be 470n - 0.47 micro. Material PolyesterAarrgghh wrote:I'll try to see if i can duplicate the problem you are describing tonight.
IC 4011. Pin 1 & 7.
decoder303 wrote:also did it, and working fine, thx for sharing
