Where are the calibration instructions?
  • Many good thoughts I've found here in forum, but still some people follow instructions and have problems at process,calibration,tunning. How can it be ? :)
  • One thing that just bit me in the ass is the noise calibration. It's not mentioned in the build instructions (it is in the service manual) but it HAS to be 130 mV RMS (NOT peak to peak), if you are using a scope to do this, you have to be measuring it correctly. 130 mV RMS is 700 mV peak to peak! If you set it to 130 mV peak to peak, CP, MA, and SD wont sound right
  • CortEnis wrote:I am also working with the Yocto and looking actively to calibrate my Yocto.
    I had to change a resistor is the noise circuit and solder resistor in parallel with another in the cowbell oscillator section.
    I can't remeber which ones I changed and the values off the top of my head but can find out if you are interested.
    Can you tell me what resistors for cowbell and noise? :)
