BD sounds just as a click?! *SOLVED
Anyone has this problem too? It just sounds like a clicky noise.Last edited by rkzr on Sep 1st, '16, 08:53, edited 1 time in total.
Well I would assume you twisted the knobs etc?
Best thing is to look through ever component and make sure it's correct, then check for solder and solder bridges...
Hej Kazper, yes twisted the knobs. Next step check all resistors. Already soldered every resistor again on both sides of the PCB to be sure...
Check the caps and pots if you can..
A misplaced cap can distroy the sound very easy.
How are you triggering it for the sequencer or from the trigger point?
Personaly I think the sequencer should be the second step in the build, so you can trigger your sounds etc.. It makes it easy to set up a easy pattern to look at the outcome via a scope.
*SOLVED - replaced 1 resistor which was showing weird readings + 1 new capacitor in BD section + replaced 1 capacitor (C31) in NOISE section! BD sounds like a boooooom!
