No sound on Crash, Hanclap & Distorted hi-tom
Edit: everything is working except crash, handclap, hi-tom now...Last edited by jonnem on Jun 18th, '16, 13:44, edited 4 times in total.
First check all power supply values on each section.jonnem wrote:
Where do i start looking for errors?
Vincent?![]()
Regards/jonnem
Do you use jumper or 0 ohm resistor for the RP resistors ?
All power supply values are correct on all 3 instruments.e-licktronic wrote:First check all power supply values on each section.jonnem wrote:
Vincent?![]()
Regards/jonnem
Yes, i use 0 ohm resistors for the RPresistors on all instruments.
This is what my hi-tom sounds like, and if you listen carefully you can hear it all the time even when its not triggered. I'm moving the pitchpot without triggering it in the the end of the soundexample.
https://soundcloud.com/ennoi/hitom
Vincent/e-licktronic on holiday?
I could really use som help here...
Take a scope and measure...
Envelopes, vca, opamp in/outs
jonnem , how is your build going? Have you solved your problem yet?
