...maybe it would be worse, because the contacts would remain in metal, usually copper, without the possibility of shielding the switches by grounding. I don't know why the engineer of the Yocto has excluded the switches from the ground, while the pots are connected. But connect them to ground is quite easy and I don't think you can do better. Probably you have also the Kacper's metal enclosure and you have noticed that without grounding you can't touch it without electromagnetic interference. The same is for the switches... For me is already good enough and unless you don't want to do only drum solo, you will not hear noises in the mix with other instruments.BedroomMusic wrote:maybe use plastic slide switchif there is some
Slide switch grounding?
All I can tell you is judge by your ears, keeping in mind who soundcloud uses compression at 128K which enhances the noise floor. It seems to me an acceptable result.
https://soundcloud.com/maxibi/yocto-sou ... tomscongas
it's true ... In some cases the noise can jump out. Perhaps increase too much the sound card gain, or by using certain effects, such as distortion or compressor, but after grounded switches and the enclosure is in control. I am very pleased to have completed this project!
What version of pcb do you have?bmaximus wrote:Thanks so much, this advice was very helpful. It does not completely solve the problem of resonance of the toms/congas (especially for the midconga) but attenuates it, so as to be able to record sound!
In this photo you can see how i've connected the swithces to ground:
Do you have one more yellow wire to a ground point?
From the photo you have made a bigger antenna by chaining them together and not connecting one end point. Otherwise it looks like a great way to get it done..
Right, that seems like a valid concern. What would you recommend, connecting the "end" point of the chain to gnd, or running separate wires from 1 gnd point to each switch body?Kazper wrote:What version of pcb do you have?bmaximus wrote:Thanks so much, this advice was very helpful. It does not completely solve the problem of resonance of the toms/congas (especially for the midconga) but attenuates it, so as to be able to record sound!
I wish one of the e-licktronic guys to have a look at this topicand provide a visual of the ground planes, so we can investigate and sort all these grounding issues once and for all
Chaining them together to a single ground point should be fine over separate runs. Just don't make a ground loop by tie both ends to separate or the same grind point.
I think from another thread there is 2 ground planes, one for the 15v circuits and one for the 5v circuits based on issues with triggering.
Just a note, chain them from left to right with short wires around the other components and when you get to the last one chain it to the nearby potentiometer mount. Use your DMM and check for continuity before the mod and after to verify that it is resolved.
I did this and have a internal power transformer, nice and quite.
Sorry for the delayed response, but unfortunately, i realize only now being quoted. About the grounding and the possibility of creating "a cure that is worse than the desease" i just tried the easiest way to solve the problem (many small cables that go from left to right to connect to the nearest ground). I believe it is the last printed circuit version, since I bought it last fall. In my case the "cure" it work enough, because the noise floor, by ear, is comparable with most of the instruments built in factory...Kazper wrote: What version of pcb do you have?
Ciao!
Can I investigate a geometric/level set method to locate ground plane objects in a robot environment and reconstruct their structure from a collection of sparse views?
Kazper: look at the rightmost jumper wire in viewtopic.php?f=16&t=720#p4305 . I think it connects the ground of the LT/LC switch to a ground lug of the SD 'snappy' potentiometer.
