[Wish List] Yocto OS Update Thread
		+1 for the originals 808 functions !
Playing and recording instruments by tapping pleeease.
effegee wrote:- Sysex dump/load of patterns & banks
+1 for Sysex dump/load of patterns & banks
+1 here as well!misa wrote:I'd like to see a bit of a different behaviour on the note entry using the colored buttons.
when you enter notes and do a sweep across the buttons, it's easy to turn on the desired notes.
but when I use three fingers to turn on three different notes, it's tricky. Then sometimes I press two buttons at once (or hold the first button too long) so that the second note is not registered.
I hope this makes sense, otherwise I'll post a short video.
It would be great if this could be changed to work as well. A small thing, but great for the overall look and feel, especially when jamming live.
+1 - I own a Quicksilver 606 and it's really a joy to have individual accent!effegee wrote: - Accent Per Instrument
A different accent pattern for BD, SN, LT, etc.
I've noticed that accented rolls (holding down the accent button when rolling a snare, etc.) are independent of Pattern accent, so it seems like this could be done. The Quicksilver 606 CPU has individual instrument accent and global accent (in a retrofit to the TR-606).
+1 as well!- Rotate Pattern
Rotate left and right per step, per four steps, per 8 steps, both per pattern and per instrument.
This one should be in the top 3 (if not top 1 )!peristilius wrote:Playing and recording instruments by tapping pleeease.
You're right - I've overseen this one...Linn808 wrote:This one should be in the top 3 (if not top 1 )!peristilius wrote:Playing and recording instruments by tapping pleeease.
BTW: is there actually somebody counting "votes" for the different wishes?
I noticed that Nava has this wonderful feature, does this mean we can also expect an update for the Yocto OS?peristilius wrote:Playing and recording instruments by tapping pleeease.
You're right, but is it really feasible ? Maybe too complicated ...peristilius wrote:I noticed that Nava has this wonderful feature, does this mean we can also expect an update for the Yocto OS?peristilius wrote:Playing and recording instruments by tapping pleeease.
Well, I imagine that the sequencer is based on the same concept and now the code is there... Just some slight adaptations to the Yocto interface maybe?Linn808 wrote:You're right, but is it really feasible ? Maybe too complicated ...peristilius wrote:I noticed that Nava has this wonderful feature, does this mean we can also expect an update for the Yocto OS?peristilius wrote:Playing and recording instruments by tapping pleeease.
