All Yocto Mods
Re: All Yocto Mods
Postby shiftr » Apr 16th, '15, 10:58
Does anybody know a snare decay mod? I'd linke to get a longer decay.
I think i probably have to change a cap for that but which one?
shiftr
Re: All Yocto Mods
Postby gihaume » Apr 17th, '15, 17:50
TR-8060 mods:
SD:
Snappy Filter :
22k(A) Potentiometer + 1k in parallel for R201 (22k)
Snappy Decay :
C51 (0,47µf) changed to 2,2µf
- in parallel a 250k (B) Potentiometer with a 22k Resistor in series
Tune OSC 1 :
2,2M(A) Potentiometer with 470k in series for R197 (820K)
Tune OSC 2 :
1M(A) Potentiometer with 470k in series for R198 (1M)
gihaume
Re: All Yocto Mods
Postby gihaume » Apr 18th, '15, 16:31
You want a longer decay than a TR-808 snare or you think your Yocto snare is shorter than the 808 one?
If second option, I think you should check the noise trimmer (and maybe change a resistor) to be sure you get the good voltage. It controls the level of the noise added in the snare (and toms and clap) and if it's too low, the snare's snappy (noise) will be more quickly gone, because initial level is already too low.
The is also some changes put as comments on the last page of the 808 service manual. Those changes are the most about the snare and they weren't included in the Yocto projet. I think they were specifically made to have a more accurate noise trimmer resulting voltage without having to change any resistor to get the correct voltage, but I'm not sure anymore.
gihaume
Re: All Yocto Mods
Postby Dr.Knob » May 1st, '15, 08:50
I think for SD filter, it's not parallel, it's serial.
Dr.Knob
Re: All Yocto Mods
Postby Altitude » Nov 24th, '15, 23:27
Putting a bunch in that I'll share shortly but I am looking for info on CB cutoff, hexinverter has it on the mutant cowbell but there is no schematic
Altitude
Re: All Yocto Mods
Postby conor » Dec 19th, '15, 17:13
That sounds great, please do post up your mods! Building mine soon, would love to hear what you did.
conor
Re: All Yocto Mods
Postby biagio.massimo » Dec 24th, '15, 16:01
Does anybody know a low, mid, hig tom/conga mod for dacay time?
biagio.massimo
Re: All Yocto Mods
Postby gihaume » Dec 24th, '15, 16:13
Still from the TR-8060 partslist:
TOMS/CONGAS:
Reverb Level:
LO - 100k Potentiometer for R232 (100k)
MED - 100k Potentiometer for R261 (100k)
LO - 100k Potentiometer for R288 (100k)
Decay:
LO - 1ma Potentiometer + 470k in series for R230 (820k)
MID - 1ma Potentiometer + 470k in series for R259 (820k)
HI - 1ma Potentiometer + 470k in series for R286 (820k)
The issue is that the decay mod sounds horrible on the conga, so a solution is using a pole and throw of the tom/conga selection switch to shortcut the mod when the conga is selected.
gihaume
Re: All Yocto Mods
Postby biagio.massimo » Dec 24th, '15, 16:24
gihaume wrote:Still from the TR-8060 partslist:
TOMS/CONGAS:
Reverb Level:
Decay:
in theory is a false problem because when the pot is set to minumum, the sound is the original conga, or no?
the 1ma pot, you can post a link??
and why sounds are terrible?
you can post audio/video if u have?
biagio.massimo
Re: All Yocto Mods
Postby gihaume » Dec 27th, '15, 09:53
Video of the Diplodocus' moded yocto at 3:10 where we can hear the tom decay mod on the conga.
He also say that the decay mod is not very audible on the high tom.
gihaume
PreviousNext
Return to Yocto v1.0 Mods
