TUTO: How to get a Full Yocto v1.0 Kit
Postby e-licktronic » Mar 14th, '15, 09:40
Dear Diyer,
Often asked ourselves the question how to order a full kit,
Here is the procedure to be followed:
Then you are ready to built a complete Yocto ;)
Enjoy!
EDIT: 12/09/16
-Yocto mouser Bom updated ;)
EDIT: 9/13/16
-220uF 35V Panasonic capacitor replace by Lelon
-Harwin Hex 10mm Spacer changed reference
-BOM complete
-BOM Updated and complete
EDIT: 8/15/16
EDIT: 6/8/16
-BOM Updated
EDIT: 5/28/16
-2200UF electrolytic capacitor replace by Kemet
EDIT: 5/23/16
-18nF Nichicon capacitor replace by Kemet
-820K KOA Speer resistors replace by Vishay
-1K TE connectivity resistor replace by Vishay
-0.01uF Nichicon film capacitor replace by Nichicon other referency
Grayhill encoder and Molex jumper cable still Out of stock
EDIT: 4/12/16
BOM complete
-TL1100F160Q e-switch replace by TL1100F260Q
-25LB22-H Grayhill encoder replace by 25LR22-H
-18nF Panasonic capacitor replace by Nichicon
As GrayHill 25LB22-H encoder will be out of Stock by Mouser soon we a have few available in the shop
EDIT: 3/24/16
BOM complete
- 3mm Red Led Lite replace by LTL-1CHE 3mm Red Led
-6N138M replace by 6N139M
EDIT: 3/8/16
BOM complete
-0.0033uF Nichicon capacitor replace by Kemet Film Capacitors 100volts 3300pF 5%
-10uF 25V Nichicon capacitor replace by Lelon Aluminium Electrolytic Capacitors - Leaded 50V 10uF 20% 5x11mm
EDIT: 2/13/16
BOM complete
-0.0033uF Nichicon capacitor replace by QYX2A332KTP
-0.0022uF Nichicon capacitor replace by QYX1H222KTP
EDIT: 2/1/16
BOM complete
-0.056uF panasonic capacitor replace by ECQ-E2563KB
-16Mhz crystal replace by FOXSLF/160-20
EDIT: 12/22/15
BOM complete
EDIT: 12/02/15
-0.027uF 50v panasonic capacitor obsolete replaced by 250v
EDIT: 11/21/15
-Mouser BOM Updated
Molex 4Pin 2inch cable out of stock (available in 8 weeks) do not order this cables if you don't need it
You can use single wire instead.
EDIT: 09/28/15
-1uF 50v LELON capacitor replaced by Nichicon
-39nF Nichicon capacitor replaced by Panasonic
-0.47uF 50v Panasonic capacitor replaced by Nichicon
-150k Xicon resistor replaced by Yageo
-250k 3362P-1-254LF Bourns trimmer replaced by Bourns 3386P-1-254LF
-33nF QYX1H333KTP Nichicon capacitor replaced by Nichicon QYX1H333JTP3TA
-3n3 Nichicon QYX2A332KTP capacitor replaced by Nichicon QYX1H332KTP
EDIT: 08/20/15
-10k resistors changed by Xicon
-120k resistors changed by Yageo
-68K resistors changed by Yageo
-56K resistor udapted by Koa Speer
-0.022uF capacitor changed by Kermet
EDIT: 07/25/15
-Nichicon 0.1uF capacitor referency updated
-18Kohm resistor out of stock updated by KOA speer
-33uF 25V Lelon capacitor (out of stock) changed by Nichicon
EDIT: 07/9/15
-0.012uF Panasonic film capacitor out of stock updated by Nichicon
-39Kohm resistor out of stock updated by KOA speer one.
EDIT: 06/29/15
220p: The parts in the mouser are 1000V, WAY too big, and the lead spacing is wrong. Recommend K221K15X7RF5TL2
2.7n: The box 5mm spaced parts that are in there now are a nightmare to mount into 2.5mm spaced footprints, maybe QYX1H272KTP?
1.8n: same (even worse considering their position) as the 2.7n. QYX1H182KTP?
Thank you for having accused us of this change.
Capacitor lead spacing updated.
EDIT: 06/25/15
-Change 1uF 50V Panasonic electrolytic capacitor referency (out of stock) by Epcos/TDK
-Replace 24 detents Bourns encoder (out of stock) by no detent bourns encoder.
EDIT: 05/30/15
-Change 1N4004 referency (out of stock) from Rectron to Diode Inc.
EDIT: 05/26/15
-Change 0.039uF polyester film capacitor referency from Panasonic to Nichicon
-Change NJM4558D (out of stock) by NJM4558DD
-Change 6N138 (out of stock by 6N138M
-Change 1N4148-T (out of stock) by 1N4148 fairchild
-Change 820Kohm resistor referency (out of stock) KOA speer
-Change Heathsink referency
Now everything are in stock and available
EDIT: 05/07/15
-Delete Atmega1284P in the Mouser BOM (now include with the Yocto half Kit)
EDIT: 04/22/15
-Replace Atmega1284-PU by Atmega1284P-PU
EDIT: 04/13/15
-PEC16-4220F-S0024 Encoder on Backorder by Mouser (Factorylead time 16 weeks). Alternative order by Digikey http://www.digikey.com/product-detail/en/PEC16-4220F-S0024/PEC16-4220F-S0024-ND/3534239
- 6mm M3 black screw on Backorder by Mouser (Factorylead time 3weeks) . Alternative order by Barenco http://www.barenco.co.uk/fasteners/machine-taptite-screw-black/product-m3-x-6mm-pan-head-pozi-machine-screw-black-800000-prod
-Updated 4K7 resistor quantity to 29pcs
-Replace Backorder parts with equivalent by Mouser
EDIT: 03/23/15
33uF/6.3v capacitor replace by 33uF/25v
EDIT: 03/22/15
I just recieved my BOM from mouser in the mail and unfortunately I just trusted your list without going over it. All the film capacitors are listed as cermamic in your new BOM.
Changed by Film capacitor
Please revise your whole BOM. I just started my build and 5 minutes in aside from the last issue C11 calls for a 220/35 capacitor and the BOM has a 22/35v listed
Update with right 220uF value
Output jack lead is too wide for the pcb hole.
It is a little hard to clip it on the board but this are the right one.
Site Admin
Re: TUTO: How to get a Full Yocto v1.0 Kit
Postby brock0791 » Mar 19th, '15, 21:16
brock0791
Postby brock0791 » Mar 19th, '15, 21:56
brock0791
Postby brock0791 » Mar 19th, '15, 23:06
brock0791
Postby tupinamba » Mar 21st, '15, 12:30
Has the list been changed and is it up-to-date now?
Thanks.
tupinamba
Postby e-licktronic » Mar 21st, '15, 23:15
Dear brock0791,
BOM updated with film capacitors and 220uF/35v electrolytic capacitor.
1/4 PCB Jack should match the IO Board
Site Admin
Postby brock0791 » Mar 22nd, '15, 21:10
Thanks. Also the bom has 6.3v instead of 33v aluminium caps for the 25uf... are these on the 5v line and 6.3v is sufficient or was it a mistake?
brock0791
Postby brock0791 » Mar 23rd, '15, 08:22
Build requires 29 4k7 resistors. Bom lists 28
brock0791
Postby e-licktronic » Mar 23rd, '15, 16:11
brock0791 wrote:Thanks. Also the bom has 6.3v instead of 33v aluminium caps for the 25uf... are these on the 5v line and 6.3v is sufficient or was it a mistake?
33uF 6.3v replace by 33uF 25V
You only need 28x 4k7 resistors
Why do you think about 29pcs?
Site Admin
Postby brock0791 » Mar 26th, '15, 01:07
Noise: x1
Accent: x3
Bassdrum: x2
Snaredrum: x1
Lowtom: x5
Middletom: x4
Hightom: x4
Rimshot: x1
Handclap: x4
Cowbell: x1
Cymbal: x1
Hihats: x2
Total: 29
brock0791
Next
Return to Yocto v1.0 Hardware
Users browsing this forum: No registered users and 12 guests
