SOLVED: Sequencer died due to shortcircuit of both boards
  • That also happened to me. I'm not sure I short circuited, but that seems the most logical explanation.
    Now, all 6 LEDS are on all the time, and it seems that the CPU reads the Shift button to be on all the time, since I don't have to press it to Init the EEP or set an instrument midi channel using it as an expander.
    I know this does not help you, but I'm in the same boat.
  • hi jonhallur!
    thx for the reply!
    vincent told me to order ICs 1-10 of the sequencer. i will replace the shift registers first and if it still fails i have to find a solution to write on the Atmel.
    viewtopic.php?f=16&t=185&p=1121&hilit=bootloader#p1121
    the Bootloader and code are available on the forum he said.
    viewtopic.php?f=17&t=180&start=10
    would an arduino board work as a USB-serial interface to write down to the amtel. or what else would i need?
    to be continued:)
    jac
  • Hi,
    Small status update report. I desoldered IC7 (that took a very long time) replaced it with a socket and a new 165N.
    The sequencer now works. :)
    Hope your fix goes as well as mine.
  • Thx for the update! We were also successful! After replacing IC2-10 it was still not working. Checked all diodes etc.
    finally with a scope there was no correct clock signal for the shift registers from the UC present. It looked like a falling moog saw instead of a sharp square wave. So we put a 1k resistor between clock out and ground for extra load of the (possible) damaged pull down transistor of the port. Et voila. The clock pulse was a lot narrower and drives all IC successfull. Dirty hack, but it works:)
