Exploring other enclosure options.
  • I've been meaning to get in on a Yocto for a while so I'm definately getting a metal case.
    Please put me down for one :D
    Cheers,
    J
  • I've been getting some questions regarding the blanking plates so I'll answer them here, since I don't have my mailing list set up yet.
    If you buy the switch but not the C14 connector, you will receive a blanking plate for the C14 hole with e-licktronic logo
    If you buy both the switch and C14 connector, you will get a blanking plate for the hole of the 15 VAC input, which has to be glued in place
    If you take neither switch nor C14 connector you will get the C14 hole blanking plate, to be screwed in place, and the blanking plate for the switch hole to be glued in place
    A popular option is to buy the switch and C14 connector, and to also order the blanking plate for the C14 hole. This way you can use your yocto with an external PSU and install an internal PSU later on.
  • hey ElSchtroumpf!
    I'm interested in purchasing a case so put me down for one as well. (it doesn't appear that I'm able to send PMs)
    Thanks!!
  • I have decided to do a 60 unit batch, which means right now I have only 4 enclosures left!
  • I want one please (but can not pm...) ! thanks !
    (I'll install both the switch and C14 connector)
  • I will take one please with switch and c14 many thanks!
  • I now have orders for 60 enclosures, so the group buy is now closed. But check this page in the weeks to come, there might be a cancellation or two.
  • I'm IN for one or two enclosure if you have some left... but can't PM you ! :(
  • If someone cancel his order, I'm up to take his place too :mrgreen:
    Thank you
