HOORAY!!! Krisbo's Yocto Issues are being solved :-)
  • Cleaned up the thread, changed the title and added my latest issue.
  • I've had a poke around and the only solder bridge I could find was between pin 14 of the 4011 and R102 which shouldn't matter anyway because they're both be connected to +15V on the schematic. I've looked with a magnifying glass and there's definitely no other solder bridges
    I'll keep looking...
  • I've replaced R151 with a higher wattage resistor. It's discoloured after testing for about 15 minutes so there's definitely still an issue there but I've been over the accent section and I can't find any errors :x
    The weird thing is my cowbell, cymbal open hi hat and closed hi hat are all working but no other sounds are working.
    In addition, if I turn up the bass drum decay all the way there a bass oscillation that sounds like it's feeding back. It gets gradually louder until it it starts clipping and won't stop until I turn the decay down. It does this regardless of whether is playing or not.
    Any ideas for things I can check???
  • More observations:
    Toms and congas are kind of working but are very quiet compared to the maracas, hats, cymbal and cowbell.
    Bass drum still has the previously mentioned issues but it and the snare will play extremely quiet sounds (snare has no snappy and bass drum has no decay). When the accent is turned up there is no sound from kick, snare, toms, clave or maracas. Cowbell, cymbal open and closed hats are not affected by accent in any way, even programming accent notes has no effect.
    To make things even more strange if I unplug it from the AC then plug it in and press play very quickly it will play a perfect bass drum, then go back to very quiet. For a while the snare was producing a little noise on the first snare played but not any subsequent snares but now the noise is doing nothing. I originally was able to get 130mV in the noise section but now I can't no matter what I value resistor I have at R127. I've tried 47K, 4K7, 2K2, 1K and even a 0ohm wire and can't get 130mV. Votages are all OK, none of my +B from the schematic have continuity with ground.
    Claves and will only work if I program at least two consecutive notes and even then it doesn't play the first note for some reason. No sound at all from rim shot or hand clap.
    So it seems my noise isn't working and there's still an issue with the accent. Been through everything and can't locate.
    I'm almost at the point we're I'm prepared to de-solder every component and source replacements for everything. After hours of searching I can't find any faults anywhere in the circuit :evil:
  • Dear Krisbo,
    Some diyer get the same R151 problem.
    Try to replace the 4011 in the accent section.
    It's not a good idea to replace R151 with higher wattage because this resistor protect the accent circuit.
    I think a lot of your problem depends on the accent issue
  • I'll order one and give it a go.
    When I say higher wattage, I've replaced it with 1/2 Watt as opposed to 1/4 Watt so not a massive increase.
  • Replaced the 4011 with a 4011BE I picked up from Jaycar and away it went! Thanks for the tip :D .
    With a 4K7 resistor at R127 I still didn't have 130mV in the noise section and the snare sounded weak. I've replaced it with 1K and I could get up to 110mV. It's a bit snappier now but I'd like to go a bit further. I'm not sure if reducing R127 more is a bad idea though.
    Any thoughts?
  • krisbo wrote:Replaced the 4011 with a 4011BE I picked up from Jaycar and away it went! Thanks for the tip :D .
    Any thoughts?
    Just a thought, I couldn't get below 250mV, and then I realized C106 was 0.47/50 instead of 47/16. It solved the issue.
    They are in the same bag, and you get a dozen out at the beginning of the built. ... check all of them
  • Hi,
    I've got the same problem i think,
    My open hat didn't work at a moment, the cowbell and the cymbal neither.
    But the closed hat works.
    So should it comes from the accent, or the trigger i think, where to look please?
    What is more weird is that before, when my hats were working, the maracas was very quiet, but now, the op hat doesn't work and the maracas has more volume, normal volume.
    so weird , where should i watch?
    thanks
    SOLVED: OK mea culpa , it was the ribbon cable!!!
    So now, my little problem is that the CY and the Cow bell don't go enough high in frquency , what to change please?
