Hi
I have a small bridge between these two components in the low tom section because they're so close. I cant seem to get rid of it even after removing the solder with solder wick, Im left with silver on the board. I cant work out how to view traces on eagle, anyone able to tell me if these are alright being connected?
cheers
Bridge between c73 and r215
C73 and R215 are indeed connected together.
The south side of C73 connects with the North side of R215.
Just download the eagle files:
https://www.e-licktronic.com/en/attachm ... achment=39
And the program to view the schema:
http://www.cadsoftusa.com/download-eagle/
There you can always check if some solder points should be connected or not.
