New Acrylic/Wood Yocto case
Postby e-licktronic » May 15th, '14, 21:15
Dear Diyer,
Here is the last design of the Yocto case. 5mm MDF woods side with 3mm black acrylic case.
you need to cut out 3mm on each side of the overlay to stick on the front panel
Here is EPS files :
Yocto_WoodAcryl_v1.1.rar
(440.05 KiB) Downloaded 1110 times
Site Admin
Re: New Acrylic/Wood Yocto case
Postby gihaume » May 15th, '14, 22:25
Magnifique!
Each side is 3 layers of 5mm MDF ? They looks like 15-20mm.
gihaume
Postby elhambre » Jun 3rd, '14, 14:03
Wow! This look killer! How much are the wood sides from Ponoko?
elhambre
Postby krisbo » Jun 4th, '14, 06:04
Does this design use the same nuts and bolts as the original case which were included with the kit?
krisbo
Postby e-licktronic » Jun 4th, '14, 11:01
krisbo wrote:Does this design use the same nuts and bolts as the original case which were included with the kit?
You need 8 extra M4x30mm screws with nuts for the wood side .
Site Admin
Postby krisbo » Jun 4th, '14, 12:41
Cool.
I had Online Laser Cutting (Australian mob) quote me on the new and the original design. I went with the original because they can only do 4mm MDF but they accidentally cut the new version. They're sending me the original tomorrow but I' just the MDF parts shy of the new case. I may have to get someone to cut the MDF pieces for me then I can pick my favourite.
krisbo
Postby Snoozr » Jun 8th, '14, 01:38
Ponoko US only has MDF in 6.4mm and 3.2mm. Which would be better? Will 6.4mm be too thick for the screws or 3.2mm too thin? Thanks for any tips :D
Snoozr
Postby Giorgio » Jun 16th, '14, 18:56
think this new design could be made with all acrylic instead of MDF? I don't see why not but figured I'd ask
Giorgio
Return to Yocto v1.0 Hardware
Users browsing this forum: Bing [Bot] and 6 guests
