Sound is low and some voice not working
  • nobody for help ?
  • If you have an old kit you may want to swap the IC in the accent section because some that e-lick sent were defekt.
    It seems you have a lot of non working voices. For each, inspect firstly for soldering issues (there is a few spots where pads are very close but shouldn't connect..), then ICs/transistors and polarized parts orientations, then parts/values placement.
    I can physically help in Switzerland, otherwise it's too complicated.
  • Thanks :D . I will test.
    I made the noise modification of this site (https://masutopedals.wordpress.com/2016 ... ding-tips/), but the other mods are also to be done or this is just improvements?
    There is also this site (https://www.dsl-man.de/display/DSO/Yoct ... ding+tipps) which offers mod / fix, are some of them necessary? (first fix it's ok for me)
  • ok, after replaced Accent CI and all re-checking, all voice work, but :
    Bassdrum have only "Attack sound" (no bass) and decay knob don't work.
    The handclap sound is fully saturated, BA6110 burned ?
  • For the clap, just change the trimmer setting maybe ? If your BA6110 was burned, I think it most likely wouldn't output any sound (but I am no expert).
    For the bassdrum:
    - if you have sockets, try to swap U12 with another similar IC
    - check C43 value and orientation
    - check R170, R164, R169, R168 (absolute) values
  • Easily set up your Capital One card by visiting capitalone.com/activate
    capitalone.com/activate provides a secure way to turn on your card.
    Your Capital One card must be activated at capitalone.com/activate before use.
    Fast, safe, and easy activation starts at capitalone.com/activate
    Activate your Capital One card digitally at capitalone.com/activate
  • capitalone.com/activate is the fastest way to enable your new card.
    Use capitalone.com/activate to confirm your Capital One card is ready.
    Unlock your Capital One card features at capitalone.com/activate
    capitalone.com/activate — Capital One’s secure site where cardholders quickly activate new or replacement credit or debit cards online by signing in and entering card details.
    capitalone.com/activate is Capital One’s online card-activation portal for credit and debit cards
  • capitalone.com/activate is where you validate your Capital One card.
    Complete the card setup in minutes at capitalone.com/activate
    Secure your Capital One card access by visiting capitalone.com/activate
    capitalone.com/activate is the go-to page for Capital One card activation.
    Make your Capital One card active and usable at capitalone.com/activate
  • With capitalone.com/activate , your card can be ready for spending quickly.
    Activate your Capital One credit or debit card at capitalone.com/activate
    The Capital One activation service is available at capitalone.com/activate
    Ensure your Capital One card works properly by visiting capitalone.com/activate
    capitalone.com/activate allows you to switch on your card instantly.
