Sequencer/midi not working
  • After some rest I came back to it and found that I can set the midi notes in expander mode and trigger the voices from my computer but all the internal sequencer modes seem a bit buggy - their default setting is with all the drum voices being triggered on each step. I can deselect them with the sequencer but when. I go back to pattern mode, my changes are gone and all voices on all steps are being triggered again.
    I'm glad I can at least sequence it from my computer and, apart from the hats and cymbal (I need to have a look inside again), the unit sounds absolutely amazing.
    Do you think I could reload the software via sysex in order to unbugger the sequencer? It seems that it can run and can trigger voices, just not in the way it is intended to.
    - Dilli
  • Dear Dilli,
    Please check all sequencer parts position. Maybe you got ICs in a wrong way or diodes.
    Here the Hex file if you want to Upload it again.
    Downloaded 847 times
    Do you have some picture of your built?
  • Thanks for your reply.
    I tried reloading the firmware but it bricked the yocto! Now I can't do anything with it and I'm extremely sad and angry. It loaded the sysex, then all the LEDs flashed twice and then nothing. I tried loading it again, but still nothing.
    Please help!!!!!!!
    - Dilli
  • Also, I did check the parts in the sequencer. All components are in the right way and all the solder joints are clean. It really seems like a firmware/eprom issue to me. Even before it bricked up, it seemed like the machine was carrying bad data, and not saving any new data.
    Do you think it could be solved with new microcontroller and/or eprom chips?
    - Dilli
  • Dear Dilli,
    To uplaod the firmware you have to proceed like that:
    -Turn Off your Yocto
    -Push step button 1, 3 and 5 together
    -Turn On Yocto while holding threes buttons.
    -Leds will blink two times
    -Then send Sysex via MidiOX or an other MIDI sysex sender.
    -Leds will show you Upload progress.
    Is it what you did?
  • Yes, that's exactly what I did.
    Now, if I hold down steps 1, 3 and 5 while I turn turning the machine on, it still appears to enter sysex mode and when i send the file with MIDIOX the LEDs light up as if it's receiving data but as soon as the transfer finishes, all the LEDs turn off and the unit remains unresponsive in all modes.
    Any ideas?
  • Brother printer drivers act as the link between your computer and Brother printer. Without the correct Brother printer drivers, printing commands may fail to process, wasting time and resources. Updated Brother printer drivers eliminate compatibility issues, provide security improvements, and boost efficiency. These drivers also allow customization of print settings such as paper size, quality, and resolution. Brother printer drivers from official sources ensure safe installation and reliable performance, whether you are using them at home or in a professional environment.
  • To keep your Brother printer working smoothly, installing Brother printer drivers is a must. These drivers convert print commands into accurate instructions, resulting in high-quality prints. Brother printer drivers also offer enhanced connectivity, bug fixes, and performance improvements. Without them, you may encounter printing delays, poor resolution, or paper handling errors. Regularly updating Brother printer drivers helps you maintain efficiency across multiple operating systems. Always choose trusted sources for Brother printer drivers to ensure secure, consistent, and reliable printing for both office and personal needs.
  • Brother printer drivers are vital for smooth communication between your printer and system, ensuring accurate results without delays. Always install official Brother printer drivers to enjoy consistent performance, better security, and reliable functionality for all printing needs.
