Kick drum has some noise tail - anyone else and how to correct?
  • Hey! Yeah, I’ve run into that issue before with my Nava as well. The noise tail on the kick can sometimes be caused by decay settings that are too long or a grounding issue. You might want to check your kick decay pot and try dialing it back a little to see if that shortens the tail. Also, make sure all your solder joints are clean, especially around the kick circuit and the noise section—sometimes a tiny bridge or cold joint can introduce odd artifacts. Pokerogue
    If you can upload the audio to a service like Dropbox or Google Drive and share the link, I’d be happy to give it a listen and see if it sounds familiar.
    Hope that helps!
  • Hi and thanks for your reply.
    Here's the audio file --> https://we.tl/t-BMmug7T8mj
    It will be available only for 3 days - if you don't download it by then, let me know privately and I can share it with you in some other way.
  • FlavioB wrote: ↑Jul 8th, '25, 13:08 Hi and thanks for your reply.
    Here's the audio file --> https://we.tl/t-BMmug7T8mj geometry dash lite
    Hello, can you share it for me? Thanks a lot
  • I'm on vacation right now - no access to my data. I'll update this thread by the end of July with the audio slice again.
  • Here again:
    https://we.tl/t-QQXxzEM6fN
    Available for the next 7 days.
