Open High Hat- intermittent fault, no decay and short crunch
  • This sounds like a bad connection to me. It's not fun, but I think you'll have to go over the circuit very carefully checking for cold solder joints, cracks, etc. Good luck! I hope you fix it! This type of problem is frustrating I know, but nearly impossible to debug over the internet...
  • There is a problem with Yocto V1 that causes the open High Hat to have no decay while rotating the knob. Instead, there is a crunchy, corrupt blast of sound, and the attack sounds perfectly normal. Sometimes the problem corrects itself, but then it starts happening again later. I have already given it to a technician, and he is unable to replicate the issue (although it is currently working again). However, I am concerned that if the issue is not fixed, it will reappear after I receive it back. Do you have any idea what the issue could be—perhaps a bad connection or something that is starting to deteriorate?
    drift hunters
  • I'm having a similar problem, I think you should check the circuit very carefully for cold solder joints, cracks. It seems annoying. Hope to fix it with you soon.
    eggy car
  • radiantdisorder wrote: Aug 9th, '23, 01:47 I'm having a similar problem, I think you should check the circuit very carefully for cold solder joints, cracks Doodle Baseball. It seems annoying. Hope to fix it with you soon.
    The welds are fine and there are no cracks. What is the problem?
