Using Yocto2 with Logic Pro
  • Hi!
    I've only just finished my Yocto build so I'm about to test what I'm writing here but what I've written works on any DAW in principle. I can't speak to how stable or well Yocto handles this. I see threads here where there seems to be some issues.
    I didn't go through the video all the way nor do I use Logic or MAC but the principles are the same. I assume you are trying to do a few things:
    1. Record and play back the Yocto pattern that you've made (done via MIDI).
    2. Record the audio from the Yocto to your computer (actual Audio)
    You'll see that the Scarlett has both a midi in / out. So does the Yocto. The Scarlett also has 1/4" line inputs. You need:
    - 2 Midi cables
    - At least a stereo 1/4" jack (2x mono TS jacks)
    Here's the configuration:
    - Yocto Midi Out to Scarlett Midi In
    - Yocto Midi In to Scarlett Midi Out
    - Yocto Audio Out L/R to Scarlett audio in L/R. For the moment set your input level on the scarlett low for now so as not to overdrive it. You will adjust this to taste when you are ready to record the audio. I'm also skipping over the individual instrument outs for now.
    On the Yocto, go to the config menu and set it to SLAVE. You are doing this because you want Logic to drive the tempo and start/stop. While here decide what Midi channels you want to transmit and receive. I think default is 1/1 which is fine for now so let's leave it.
    In Logic, head to you preferences and confirm that you have your scarlet selected for both midi in and out transmissions. You will also want to switch on the clock sync here. That 'closes the loop' so that Logic is the master software running the start/stop of the Yocto.
    Now you can follow the video. You have a few ways you can do this but if it was me I'd want to capture my midi loop and capture the audio too. This can be done in one go or over several recordings but basically you will create a midi channel to capture 'channel 1' patterns during recording. You can then send this pattern back to channel 1 on playback. If you're happy with the sequence of patterns create an audio channel in logic and capture the stereo signal at your desired input level.
  • There are no strict rules. This freedom allows players to explore their ideas without fear of making mistakes.
  • For the man talking about prx facial, derma prp, best facial for face lift, skin care fillers, surgical thread face lift, the body treatment, dermal fillers what is, laser spas, aesthetics laser, led red light therapy for skin, I highly suggest this great Best laser treatment Sarasota url or chemical peel for your face, derma prp, laser treatment for breast lift, best facial laser resurfacing, medical spa, skin tightening face laser, aesthetics and wellness, skin rejuvenation treatment laser, environ cool peel treatment, medical spa services, which is worth considering with this recommended laser spa Sarasota tips not to mention the perfect derma chemical peel, chemical peel florida, face filler injections, aesthetics laser, best face laser treatment, best peel, aesthetics and wellness, best med spa sarasota, aesthetics procedures, lip enhancement, on top of this cool laser for face treatment url which is also great. Also, have a look at this click for source on laser treatment spots face Sarasota info together with botox for lip enhancement, best med spa sarasota, best non surgical skin tightening, about laser treatment, lip fillers sarasota, facial rejuvenation fl, facial tightening, best face proportions, the best peel for face, skin care microneedling, not forgetting sites such as this homepage about laser facial Sarasota url not forgetting sites such as platelet rich plasma hair loss near me, best face filler injections, facial treatment services, best laser treatment for skin texture, dermal filler lip enhancement, read more about alongside all non invasive facial skin tightening, lip enhancement fillers, radiofrequency body treatment, best chemical peel for face, rejuvenation skin care, for good measure. Check more @ Useful Laser Treatment In My Area Tips c44f6_0
