Nava Hi-hat and Ride problem
  • Did you solve the problem with hi-hat and ride?
    I have almost exactly the same trouble with mine Nava 909.
    Everything worked perfectly the first six months, but then the crash stopped working, before the hihat and ride and got wierd, just like you described.
  • bump
  • dear Zener,
    i have the same problem with ride and crash. have you found a solution?
    thanks in advance
  • Totally forgot about this thread.
    The problem in my case was a bad 74hc595 register in the accent circuit.
    Replacing it fixed the issue.
    I've also gone further and installed the mux boards which address the accent issue.
