Dai che è facile!Masuto wrote:Amazing! Will try tonight!!! HUGE THANK YOU!!!
I'm already using that one.. Also think Cocteau mods are using it. Can't expect people to drill holes in the case for a feature like thathelectromagneticus wrote: It's worth noting that the unused third trigger pin on the ATMEGA could be repurposed as an input...
AAAAND... no it's not working LOL i told you guys i am very unlucky with these things.rv0 wrote:If you get stuck people will help you, don't worry!
Haha don't worry, some tips to help you:Masuto wrote:AAAAND... no it's not working LOL i told you guys i am very unlucky with these things.rv0 wrote:If you get stuck people will help you, don't worry!
I followed your instructions to a tee. downloaded E6, set config and all. I tried a delay of 200, 300 and turbo set to none or 1x
-i put YOCTO in PATTERN PLAY MODE,
-i press on and 1-2-5. All leds blink twice.
-i am quickly sending the .syx out of my MIDIMAN (cant get more basic than that).
NO LED play. All leds are off.
When the send bar is through, after half a minute YOCTO shows the blinking first pattern light. THATS IT.
To check features, i tried to edit a pattern using tap (shift) and it's not working
i tried also using midiox, 300 delay.. no avail.
Sorry to sound retarded but:rv0 wrote: - does not matter which mode yocto is in, as long as it's off when you start
- set delay to 16.. 200 is probably a verrrrry long delay
- Not 1-2-5 but 1-3-5
