Hello, i've just got an social entropy engine. As i try to sequence my nava i find no luck in getting it to accept midi notes. I've looked at the manual but somehow i cannot get into the midi menu by pressing "instrument select+guide" I've set the midi channels on 1.
Would really appreciate if someone could help me out.
Have a great weekend,
Konrad.
				external sequencing of the NAVA (help)
it recieves midi from both my keystep and my social entropy, however when i lay out my notes in my sequencer and press play no sound is heard. Is there any settings for the nava, like "turn of internal sequencer" or something?
				Same problem for me. I have been trying to sequence the Nava on my Digitakt but no luck so far... I can hear the different voices when I trigger them thru the digitakt chromatic mod (sequencer off) but as soon as I program notes on the digitakt sequencer and press play I get no sound.
Has anybody been able to sequence his Nava with an external sequencer?
I can sequence the Nava without problem with my MB-Seq V4.
Just have to enable external sequencing in the config page (shift+tempo --> first parameter) and then set the right RX midi channel as your seq.
Guillaume
Guillaume
Hi Quick question. Can you sequence the NAVA with an external controller ad 'write' the pattern into the NAVAs sequencer? I can do this with my electron machinedrum when set to live record mode for example.
