New run of Chia Shin TR-909 style knobs
Re: New run of Chia Shin TR-909 style knobs
Postby KlangGenerator » May 14th, '19, 18:22
automatique wrote:I repeat myself: Are there any other Extra9-Builders out there who need some xtra caps too??? I bought 2 sets, but I'm still missing some knobs... I guess Klangenerator will make it happen to sell small ammounts if we are enough to devide the "normal" set into pieces ;)
Smaller sets are no problem of course... Just write me the number of knobs you need and I'll give you a quote. ;)
KlangGenerator
Postby kmosch » Jun 10th, '19, 20:03
Hy, i need also a Set for a Nava Extra9. Please send me a PM, i'm new and can't send PM. Greetings
kmosch
Postby KlangGenerator » Sep 2nd, '19, 12:25
I still have around 80 knob sets available. I also have some small knobs with T18 shaft for the Extra9 mod pots. These also need to be drilled to make them fit, but it is much easier compared to the D-shaft knobs!
If you want to have a set please send your request to service@klanggenerator.com
KlangGenerator
Postby KlangGenerator » Oct 11th, '19, 13:51
I got some new knobs for the Extra9 (same TR909 style). They are round shaft 6mm and don't require drilling. There is a small nib inside though that needs to be removed to make them go all the way down.
KlangGenerator
Postby TEAMBANZAI » Oct 12th, '19, 17:49
Just emailed you about a set! :D
TEAMBANZAI
Postby KlangGenerator » Feb 7th, '20, 06:47
Knobs restocked and available ;)
KlangGenerator
Postby ferrochrome » Feb 10th, '20, 13:43
KlangGenerator wrote:I got some new knobs for the Extra9 (same TR909 style). They are round shaft 6mm and don't require drilling. There is a small nib inside though that needs to be removed to make them go all the way down.
I'm interested in a complete set for a nava with extra9. Do you have pictures of a unit featuring the knobs?
ferrochrome
Postby KlangGenerator » Feb 10th, '20, 14:35
https://www.instagram.com/p/B1vMPj-oA3T/
KlangGenerator
Postby njosnari » Feb 19th, '20, 21:35
I'm also interested in a set for a Nava extra 9. Are there any still available?
njosnari
Postby KlangGenerator » Feb 20th, '20, 09:36
njosnari wrote:I'm also interested in a set for a Nava extra 9. Are there any still available?
Yes, a new run will be available in more or less 2 weeks. Check your PMs! ;)
KlangGenerator
PreviousNext
Return to Nava Hardware
