How to burn Yocto v2.0 firmware with an Arduino
  • Hi Keith,
    Thanks very much for this although it doesn't seem to work for me.
    I'm also using a mac and have followed the instructions to the letter but my Yocto has no gone a bit mad.. all lights are stuck on and the screen is blank?!
    Do you have any idea what could have happened?
    R
  • It may still be in bootlooader mode. Don't copy the code I provided, as various file locations will be different. Copy the code from your own Arduino log window and add the correct filename for the Yocto firmware.
    When you enter the command in the terminal window, you'll get a bunch of data back again. Right at the end, it'll report success or failure. What does it say?
  • Yes, I must have mistyped a directory. Works perfectly now. Thanks very much for your help!
