Extra9 - NAVA Expansion Kits
Re: Extra9 - NAVA Expansion Kits
Postby secrethero303 » Jun 12th, '19, 21:38
poser1 wrote:It's great to hear that people are receiving their cases! I was wondering if anybody in the states has had one arrive yet? Thanks...
Mine arrived last week!
secrethero303
Postby kmosch » Jun 16th, '19, 16:59
hy, i have problems with BD attack and noise, and SD snappy since i've installed the extra 9 pcb. They do nothing, without pcb the function was ok. have anyone the same problem? Greetings.
kmosch
Postby KlangGenerator » Jun 16th, '19, 18:18
kmosch wrote:hy, i have problems with BD attack and noise, and SD snappy since i've installed the extra 9 pcb. They do nothing, without pcb the function was ok. have anyone the same problem? Greetings.
I'd say IC33 died. To find out, remove IC33 and place it's companion (IC32) inside the socket.
KlangGenerator
Postby Macgyverradio » Jun 19th, '19, 01:47
Haven't gotten mine yet. But I'm in California might take a little longer.
Macgyverradio
Postby kmosch » Jun 24th, '19, 14:33
so i get 2 new mitsubishi 4006er, both was died. so SD and Handclap is ok, BD Attack and Noise do not. On R10 i have the Signat from the 4006, but how looks the signal at the test point for noise? the same?
kmosch
Postby mmoody » Jul 5th, '19, 23:52
Are any kits still available (no case)?
mmoody
Postby poser1 » Jul 7th, '19, 00:32
My case from Kacper finally arrived yesterday! Looks good so far but I haven't checked yet to see if everything lines up correctly with the PCB...
poser1
Postby e-licktronic » Jul 13th, '19, 19:27
poser1 wrote:My case from Kacper finally arrived yesterday! Looks good so far but I haven't checked yet to see if everything lines up correctly with the PCB...
Lucky guy i'm still waiting for mine :(
Can you share picture of yours ?
Site Admin
Postby poser1 » Jul 20th, '19, 03:10
Sure, I took some photos but can't figure out how to post them... shall I just PM them to you?
poser1
Postby secrethero303 » Jul 23rd, '19, 02:13
I had the same issue with mine after the Extra9 upgrade. Turns out the problem was with my ability to clearly read the instructions. I had all of the wires going to the attack pot and didn’t see that the 2nd wore is actually supposed to go to the pcb. Once I fixed that everything worked 100%. Hopefully your issue is something simple too.
secrethero303
PreviousNext
Return to Nava Mods
