Excessive NAVA Expansion Kit
  • KlangGenerator wrote:Did you drill the Chia Shin knobs to make them fit on the knurled mod knobs? Do they sit tight?
    I drilled them with a 6mm drill bit. They sit nicely tight and at the same height than normal ones. Some Tayda pots may make some a bit hard to remove (the other kind ones are just perfect), but with a cable to catch them it's very doable.
