- Posts 89
so like I said in different other threads, my Yocto is finished and working fine.
The only thing that is a bit odd (maybe quirky is the right word, nothing I couldn't leave that way, but I am wondering if this behavior is normal): when I turn on the Yocto and start making beats, the first few sounds of the handclap are without reverb - only the 3rd or 4th hit has verb.
Why does this happen? Is this a trimming problem? With my limited knowledge of electronics, I assume that a condenser is loading up, and only when it has reached the right voltage does the verb set in -- should that be this way?
just curious, really not a problem...
- Posts 28
it depends how you programmed your beats : if you retrig the clap before the end of the reverb tail, you won't hear reverb. notice that TM3 set the reverb "balance" and the harshness of the clap
- Posts 37
misa wrote:so like I said in different other threads, my Yocto is finished and working fine.
That happens on mine and I read the original Roland TR-808 did this too.
- Posts 89
Ah, so it's quirky -- I love it!
- Posts 6
Happens also on my original 808!
