SquareSeq vX.0 by e-licktronic
Here we talk about e-licktronic projects (hardware, software) like SquareSeq, Ablickton...
Re: SquareSeq vX.0 by e-licktronic
Postby soulomon » Apr 2nd, '14, 08:18
thank you for your quick reply.
I'm using Arduino Uno with 1.0.5 IDE. We actually built two SquareSeq and both give the same result. In-out connections rechecked, even swapped some flat cables to be sure those weren't the problem.
But we have replaced wiring_shift.c with the SRIO compatible one and modified shitIn/Out in arduino.h as for SRIO instructions. Could that be the culprit?
Thank you.
Regards,
Soulomon
soulomon
Postby soulomon » Apr 2nd, '14, 11:03
I've checked SRIO.cpp against SquareSEQ.cpp and they're almost identical, even the wiring_shift optimized functions are identical to those included in SquareSEQ.
This evening I'll try the SRIO tutorial, after rechecking the connections once again!
http://www.e-licktronic.com/en/content/ ... brary-srio
I'll keep you updated.
Regards,
Soulomon
soulomon
Postby soulomon » Apr 2nd, '14, 19:04
I have a single Dilicktal connected from IN socket to Midilickuino Board socket. It's switched to prog / ain.
I'm trying the SRIO tutorial sketch and as soon as I run it all leds light up. Serial monitor shows buttons actvity though.
Same with the Ablickton sketch and SquareSeq.
The only sketch that I've found working correctly with leds is the Dilcktal_MIDI_v1.0. It's also the only one that doesn't use the SRIO or derived code, but that's way over my head to hope to find the problem there.
It's working for you so I'd love to understand what's wrong with my setup. Any suggestions?
Thank you.
Regards,
Soulomon
soulomon
Postby e-licktronic » Apr 2nd, '14, 21:21
Dear soulomon,
You don't need to change this file with last update of libraries. That's why you got this problem.
Simply return to the original file, download Squareseqv1.1 and everything would work properly ;)
Site Admin
Postby soulomon » Apr 3rd, '14, 18:35
Ok it's working now!
Thank you for your support.
Regards,
Soulomon
soulomon
Postby lgranie » Apr 22nd, '14, 17:20
taeubler wrote:I made a simple case for the Sequencer...
have fun :-)
I will try mine but I replace the 2 Dilicktal with 2 Lickogic.
Do you know if the screws are at the same place on this board?
Thx,
Laurent.
lgranie
Postby e-licktronic » Apr 22nd, '14, 20:51
lgranie wrote:Do you know if the screws are at the same place on this board?
Screw holes are in the same place. Have look on boards dimension https://www.e-licktronic.com/en/attachment.php?id_attachment=37
https://www.e-licktronic.com/en/attachment.php?id_attachment=36
Site Admin
Postby krisbo » May 1st, '14, 04:17
Is there any way to add a swing function to this sequencer like the old MPCs?
krisbo
Postby e-licktronic » May 1st, '14, 08:40
Dear Krisbo,
We didn't work on shuffle or swing function yet, but you need to change the number of ppqn by step.
Example: first step = 6ppqn, next step=5 ppqn next step =7ppqn....
Site Admin
Postby krisbo » May 1st, '14, 08:52
If I can't get my hands on a Yocto I might have to build the voices individually from schematics and go for one of these sequencers.
krisbo
PreviousNext
Return to Projects
