Yocto2 Mouser BOM... Obsolete components?
Here we talk about e-licktronic projects (hardware, software) like SquareSeq, Ablickton...
Postby njosnari » Sep 5th, '17, 14:25
I was just about to pull the trigger on my Yocto2 order, and I see in the Mouser BOM, there is a component no longer listed, or obsolete. 3 x 50volts 0.0018uF Film Capacitors are needed, but no longer available (Mouser# 647-QYX1H182KTP, part# QYX1H182KTP) http://eu.mouser.com/Search/ProductDetail.aspx?R=QYX1H182KTPvirtualkey64700000virtualkey647-QYX1H182KTP
Can anyone recommend a suitable replacement on Mouser?
njosnari
Re: Yocto2 Mouser BOM... Obsolete components?
Postby njosnari » Sep 5th, '17, 17:50
Would this be suitable? I can't tell the lead spacing on the original...
http://eu.mouser.com/ProductDetail/KEME ... DA8g%3d%3d
njosnari
Postby BastienL » Sep 6th, '17, 16:24
The1.8n Nichicon QYX that are used have a lead spacing of 2.56mm. Generally film box capacitors comes with a 5.08mm lead spacing, the one you mentionned is 7mm, so I would recommend to check for a 5.08mm one (like this one http://www.mouser.fr/ProductDetail/KEME ... 7P59qbc%3d), you will have to bend the leads a bit though.
If you're really looking for Nichicon caps, Digikey still have them, or you can also check Tayda, they have capacitors in a similar package.
BastienL
Return to Projects
