A little help with code?
Here we talk about e-licktronic projects (hardware, software) like SquareSeq, Ablickton...
Postby ceecrb1 » Sep 24th, '13, 17:01
Hi there, I am trying to modify you're dilicktal example so that it works with momentary presses rather than latched...
meaning, a midi note is sent while I hold a button, but on release the midi note off is sent.
help?
ceecrb1
Re: A little help with code?
Postby e-licktronic » Sep 25th, '13, 16:30
Hi ceecrb1, welcome on the forum.
Try the last example of SRIO library tutorial here. I think this is exactly what you need. Simply replace CC message by Midi noteON and noteOFF message.
E-licktronic
Site Admin
Postby ceecrb1 » Sep 25th, '13, 20:12
hi there..
Yeah that seems to be more what I am just looking for!
now just to work on the "SR" was not declared in this scope compile error.
I have added the library etc.. and even just trying the most basic example..
#include <SRIO.h>
void setup()
SR.Initialize();
void loop()
ceecrb1
Postby ceecrb1 » Sep 25th, '13, 22:57
Fixed...
premission problems with the library.. I had to run the arduino program in administrator mode.
ceecrb1
Postby e-licktronic » Sep 26th, '13, 06:46
Fixed...
;) If you got other questions feel free to ask.
Site Admin
Postby ceecrb1 » Oct 13th, '13, 23:06
Hi there..
The 2nd button set arrived.. I´ve used them both this weekend..
Out of interest... Is there a way to easily make the first 12 buttons momentary and the last 4 as toggles?
I am actually using this to run effects on a profesional lighting desk, and its going very well!!
ceecrb1
Postby xarolium » Oct 14th, '13, 15:10
Hi Ceecrb1,
Download Ablickton code here and there are some function on the code to choose between toggle and momentary.
I think it's the easiest way to begin ;)
xarolium
Postby Keylec » Jan 8th, '14, 20:02
Hello!
I am interested in using an LCD Display for the Lickogic Midi out.In the LCDBoard tutorial you only use the midi In.
can you help me with the code?
Keylec
Postby e-licktronic » Jan 10th, '14, 07:02
Dear Keylec,
Could you describe your project on a new topic that i could help you to coding
Site Admin
Postby yuehuazz » Feb 12th, '19, 05:24
I have the same problem
https://www.allicdata.com
yuehuazz
Return to Projects
