Yocto² switches in hihat section.
Postby kacperpawluk » Aug 14th, '17, 10:18
Is anyone there have any idea how to use extra switches in hihat section?
kacperpawluk
Re: Yocto² switches in hihat section.
Postby poser1 » Sep 5th, '17, 02:23
This is not necessarily for the hi-hats, but I was going to try using these 2 switches to switch between various resistor values in the "metal" oscillator tuning section (i.e. various of R40 through R43) to create different frequencies with the hexinverter oscillator and thus different "metal" sounds....
poser1
Postby kacperpawluk » Sep 11th, '17, 14:47
Thanks for reply! What resistor values did you used? Thanks!
kacperpawluk
Postby poser1 » Sep 11th, '17, 18:44
Actually I haven't started the build yet, so I don't know... I'll probably use trimmers so that I can tune in a couple of different combinations that sound "right" to my ears...
poser1
Postby Dr.Knob » Oct 12th, '17, 20:21
hi-pass TR808 hats:
There is another interesting mod to be done on the hats, with a switch that allows to select the white noise or the noise that colors the cowbell (from the schmidt trigger) On the other hand you have to cut via and improvise, i do not own yocto² so i can give no more explanations. But by observing the scheme of TR808 and probing yocto², you can find out how. Having the hats with the schmidt trigger makes it possible to have different hats sounds.
There are things possible with the hats.
Dr.Knob
Return to Yocto² Mods
