Current Yocto2 OS in HEX
Postby blotvard » Nov 10th, '17, 09:51
Does anyone have the firmware? I need to make a replacement chip.
What version do people have? Mine was Yocto_v2_002.
blotvard
Re: Current Yocto2 OS in HEX
Postby blotvard » Nov 13th, '17, 18:14
Here it is with Vincent's permission: Yocto_v2_002.hex
I used a TL866 programmer with the following settings:
Fuse Low Byte: 0xD6
Fuse High Byte: 0xDC
Extended Fuse Byte: 0xFD
Lock Bit Byte: 0xFF
blotvard
Postby cmroosen » Apr 4th, '18, 16:51
Do you need to load the bootloader first on the chip? Can you use the Yocto v1 bootloader for this?
cmroosen
Postby blotvard » Apr 6th, '18, 22:32
No need, I just flashed a new chip with the programmer.
blotvard
Postby peskado » Jul 27th, '18, 22:20
blotvard wrote:No need, I just flashed a new chip with the programmer.
Hello!
I have same problem
What software are you used for burn chip?
peskado
Return to Yocto² Software
