SOLVED - Master output overdriven on startup
I'm experiencing an overdriven master output on starting up the unit before it fades away after a few seconds and becomes clean. This is not experienced on the individual outputs. I've swapped out the opamp and confirmed correct parts still all the same. Any thoughts?
I swapped out the 2 2SC2878(B) in the muting circuit, these came with the kit, with a pair of 2SC2878(A) and now it is clean from start up.
