SOLVED - PC-2 causing instruments to trigger
  • I had a grounding issue on the main board, where the previous builder had tried to desolder the PSU header damaging the +12v trace to the rail and also the ground. I'm not sure how I missed this as I had already repaired the +12v trace when starting work and must have confirmed continuity to the ground plain (or maybe not ???).
