Help, I maybe burn something but I don't know what
Posted: Jan 20th, '19, 06:42
So, after all the assembly, I was about to turn on for the first time and the 5V regulator temp went really high and nothing happened (LCD was low red for a while and some LEDs light. After that everything shutdown.
Then, I unplug both boards and I measured the volts and everything looks fine. So, probably I didn't burn the regulator.
Also, the +/-15V section was fine.
After A LOT of searching I've notice that I soldered one of the memory modules (the IC23) upside down. I've removed it from the circuit (destroyed on of the pins in the process and ordered another one). I am waiting for the new one to arrive. But, my question is, if that guy shorted the 5V rail somehow, what else should I debug to see if I also burned???
