Hi guys,
Another noob with a problem here. I've completed my Yocto V2. Well... almost because everything seems to work except the encoder dial. Push function works, but the dial doesn't do anything.
I really hope someone can point me in the right direction to troubleshoot this. Any idea where to start looking?
Encoder dial not working [SOLVED]
Try to flash firmware. I had a similar problem.
Thanks. I'll try that.
Do you know where can i find the latest firmware for Yocto V2?
here -> viewtopic.php?f=28&t=1557
Hi Lukep_gdansk, thanks for the link.lukep_gdansk wrote:here -> viewtopic.php?f=28&t=1557
Did you upgrade from an older firmware version to Yocto_v2_002 to make the dial work?
I'm afraid this won't work for me because i'm already running the latest Yocto_v2_002 firmware (which is the latest version i believe).
just try reflash
cheers
cheers
Ok, i will try that.
I'll need some time to get a programmer but will report back here.
Thanks again!
Thanks again!
Hi Lukep_gdansk,
It worked! Thanks!
After reprogramming the ATMega chip the dial works.
It worked! Thanks!
