Page 6 of 12
v1.020 FW: MIDI bug?
Posted: Jan 19th, '17, 20:14
by southpole
In the 1.020 FW Midi in is not recognised after power up until i change the Midi channel at least once.
eg. from 10 to 9 and back to 10...
Cheers
Re: Nava v1.0 Firmware
Posted: Jan 19th, '17, 20:33
by Data Jam
finally updated to 1.020...
in slave mode still sync issues, i have to hit the button very fast to change pattern to not have it un-sync for few ms... and you hear that very well that it just fell out of sync for a moment, after that its in sync again.... but hold the button a bit to long while changing patterns, sounds just awful...
not sure yet there are other problems how i use it atm, but this almost makes it unusable...
Posted: Feb 11th, '17, 00:32
by lukep_gdansk
Is it possible to get 1.21 in hex format file?
Posted: Feb 11th, '17, 03:36
lukep_gdansk wrote:Is it possible to get 1.21 in hex format file?
inlcuded in the RAR file
Posted: Feb 11th, '17, 07:24
by lukep_gdansk
e-licktronic wrote:lukep_gdansk wrote:Is it possible to get 1.21 in hex format file?
*many thanks. works great.
Posted: Feb 19th, '17, 15:40
by Grizzlydj
Tap mode bug in last version not fixed!
Posted: Mar 13th, '17, 15:28
Grizzlydj wrote:Tap mode bug in last version not fixed!
Should be solved this time
Nava v1.023
Posted: Mar 13th, '17, 22:05
by drifter7508
Is it a "must" to do the hardware changes? I rather not go in there again for the 100:th time.
What do you mean by improved velocity in this case? What was "bad" with it before?
Posted: Mar 14th, '17, 04:43
drifter7508 wrote:Is it a "must" to do the hardware changes? I rather not go in there again for the 100:th time.
Nothing is bad with the 47nF capacitor but we found that velocity response increase with a lower value that mean that the BD sound more punchy
Posted: Mar 14th, '17, 05:01
by hofmann25
e-licktronic wrote:drifter7508 wrote:Is it a "must" to do the hardware changes? I rather not go in there again for the 100:th time.
What is this? What capacitor? Or is this a mod?
