Nava v1.0 Firmware
Re: Nava v1.0 Firmware
Postby m4d » Apr 19th, '20, 16:28
At least that's what I've read here. 1.023 needs the original 4051s in place to work properly.
m4d
Postby emenel » Jun 13th, '20, 13:17
emerse wrote:i can also confirm im getting significant volume differences on all my drum voices, the rim shot is super loud. the kick is fairly quiet in comparison to the majority of the other voices, you basically have turn all the other voices right down to get a decent pattern with a balanced kick..
anyone have any ideas on how to troubleshoot this problem, or is it firmware related?
cheers
Has this issue ever been resolved?
I have a new build of the 1.02 boards with the latest firmware and the levels of each voice are still wildly different. The rim is twice as loud as the BD and Toms.
Is this a hardware issue or firmware? If hardware, is there a component value that can be changed to even them out?
emenel
Postby KlangGenerator » Jun 15th, '20, 06:38
If you replace R419 with a 10k resistor the level will be reduced.
KlangGenerator
Postby emenel » Jun 15th, '20, 19:32
KlangGenerator wrote:If you replace R419 with a 10k resistor the level will be reduced.
Thank you! I will try that.
emenel
Previous
Return to Nava Software
