Page 1 of 12
Nava v1.0 Firmware
Posted: May 30th, '16, 09:47
Dear Diyer,
Here is the last version of Nava v1.0 firmware
Changelog:
v1.028beta:
-Should fix encoder issue
Downloaded 1562 times
v1.028 by zabox :
Fixed:
- Digital instruments: velocity changes in midi play, tap mode and in combination with total accent
- Led flickering
- Various minor improvements
Code: Select all
New features:
	- Flam
	- Low latency expander mode
How to use flam (BD, SD, Toms):
	- Press "Instrument Select" + both instrument buttons to select flam
   	  (indicated by a lower case letter, e.g. bD, sD, ...)
	- Hold "Shuffle / Flam" and press step button 9-16 to select the inverval (20ms-48ms)
How to use expander mode:
 	- Set sync to "EXP" to enter expander mode
	- Press "Guide" to show triggers
	- Press "Mute" to enter mute mode
	- Press "Bank" to enter gate mode and select instruments like in mute mode
         (gate cuts the sound at a midi note off message)
Notes:
	- Gate has almost no effect on SD and Toms
	- BD gate increases when turning the decay pot counter clockwise
	- Trig-1 is selectable in both mute and gate modes
Nava_v1_028.zip (65.98 KiB)
Downloaded 1711 times
v1.027 by zabox :
Fixed:
- Pattern change bug in slave mode
- Hihat cuts in tap mode
- Short trig-1 pulse when played over midi
Nava_v1_027.zip (62.76 KiB)
Downloaded 1468 times
Beta version with Flam. Read this carefully
Downloaded 1341 times
v1.026 by zabox :
Fixed:
- Mux issue with external trigger
- Mux settling times
- External trigger length drop
- Din clock phase
- Midi clock out lag
- Pattern group bugs in step write and pattern play mode
- Shuffle update in tap mode
- Crash when deleting more than the last track position
- Double midi real time messages on midi out in slave mode
- Various other bugfixes
Updates:
- Instruments mute while holding clear
- In tap mode: hold clear + instrument to delete steps
- Seperate CH/OH mute (can be set to combined mute again in global settings page 2)
- Pattern numbers match the step button numbers
- Track and external instrument positions start at 1
Nava_v1_026.zip (63.98 KiB)
Downloaded 1406 times
v1.025:
-Fixed MIDI play mode
-Pressed Pattern play button alternate access to Step and Play mode (no need to press shift again)
-Pattern Group incremente in MUTE mode (fixed)
-Improve Tap mode HH
-Various bug fixed
Nava_v1_025.zip (60.47 KiB)
Downloaded 1475 times
v1.024:
-Improve accent response
WORK ONLY WITH THE MUX/SH BOARD MODS
-Trig out length is 10ms now
Nava_v1_024.zip (23.08 KiB)
Downloaded 1846 times
v1.023:
-No more HH ticks background noise
-Improved velocity on all instrument
You should replace C89 and C163 by 10nF (Build manual and Mouser BOM updated) ;)
-Clear pattern now set minimum velocity that increase velocity response
-CH Tap Mode bug fixed
-Improve Slave sync when pattern save/change (Please Keep up to date on improving sync cause we do not have this issue with our Midi interface)
Nava_v1.023.zip (59.65 KiB)
Downloaded 1955 times
v1.022:
-Fix OH select Bug
Nava_v1_022.zip (59.24 KiB)
Downloaded 1485 times
v1.021:
-Tap Bug fixed
-Velocity HH can be saved
-OH Velocity and Total ACC conflict solved
-Improved BD, SD and HC velocity response
-RX Midi channel issue solved
-Buttons functions improved
-Sync test in slave mode with a TR505 and with Ableton and Midi interface.
Sync with hardware is perfect but Nava loose some clock signal when sync with a software thru a Midi interface.
Replace R365 value by 1K and R314 value by 4K7 to increase Midi signal should solve this issue
Nava_v1_021.rar (56.01 KiB)
Downloaded 1484 times
v1.020:
-Fixed CH and OH bug in MIDI play
-Add a config page that allow you to set the sequencer pattern change SYNC or FREE: -Push Tempo button twice while holding SHIFT button to access to the second config page. Use the encoder to select "pCH" (pattern change) SYN => SYNC or FRE => FREE. push the enter button to store new sequencer setup
Nava_v1_020.zip (22.59 KiB)
Downloaded 1707 times
v1.019:
-Fixed Middle Tom low volume
-Now respond to Midi note ON velocity 0 message as a Midi note OFF message
Nava_v1_019.rar (21.15 KiB)
Downloaded 1467 times
v1.018:
-Fixed Total Accent issue on crash and ride instruments
Nava_v1_018.rar (55.13 KiB)
Downloaded 1405 times
v1.017:
-Original version
Nava_v1_017.rar (20.86 KiB)
Downloaded 1390 times
Re: Nava v1.0 Firmware
Posted: May 30th, '16, 12:34
by housedet@comcast.net
Is it safe to assume that this firmware update will be loaded on the IC when the next batch of kits are ready for purchase? I hope so since I don't have the know how to perform such a task. Thank you.
Posted: May 30th, '16, 13:20
by AonFluX
I really hope that the build instructions will be updated with info on how to update the firmware.
Posted: May 30th, '16, 13:21
housedet@comcast.net wrote:Is it safe to assume that this firmware update will be loaded on the IC when the next batch of kits are ready for purchase? I hope so since I don't have the know how to perform such a task. Thank you.
Next batch will have v1.018 firmware
Posted: May 30th, '16, 20:36
Thank you for that, and I'm truly looking forward to receiving my email stating that the Nava's ready for purchase, I'm very ready for it.
Posted: Aug 22nd, '16, 08:52
by drifter7508
Mid Tom is now working at the same vol as the Low Tom. =) Thx!
(I still think that the Hi-Tom is to high in volume towards those 2)
Top prio. on next firmware:
- Fix the pattern changes to match the original 909... so that a pattern plays its 16 parts and THEN changes to the next pressed pattern number.
Not like now, where it changes instantly and abrupt.
Posted: Aug 22nd, '16, 13:42
by decoder303
yeah, I can confirm that the mid tom is now working, and also that the high tom seems to be have a slightly too high level compared to low and mid tom. And I also would appreciate if a pattern would finish all 16 steps before the next pattern plays after a pattern change. Thanks for the effort and fixing the mid tom, we are getting closer to the perfect 909 clone :mrgreen:
Posted: Aug 22nd, '16, 16:41
by AonFluX
decoder303 wrote:yeah, I can confirm that the mid tom is now working, and also that the high tom seems to be have a slightly too high level compared to low and mid tom. And I also would appreciate if a pattern would finish all 16 steps before the next pattern plays after a pattern change. Thanks for the effort and fixing the mid tom, we are getting closer to the perfect 909 clone :mrgreen:
After playing around a bit, I would vote for the pattern change to be switchable. Meaning that you can choose to either change when button is pressed or after pattern-length.
Because it is very fun to "play" the Nava switching back and forth quickly between patterns :)
Posted: Aug 24th, '16, 08:33
by beeb
Having a setting for the pattern change would be lovely, I agree with AeonFluX on this one!
Regarding the mid tom, volume is fixed indeed (yay!). I still have a slightly shorted decay on the mid-tom though, but it doesn't bother me that much (not sure if anyone else has this difference in decay)
Posted: Aug 24th, '16, 10:40
by Loons
Does it erase our saved patterns when we update firmware?
thx
