Bugs and suggestions
Get the OS fixed and solid. Then worry about extra features. That's why OS's get unstable. Cause ppl try and cram in features without a solid base.
Wisely spoken hoffman and i totally agree. The Nava fw has always been its weakest link.
The first update is almost ready, i have sent the files back to Vincent. All bugs in my list are fixed.
Changelog:
Fixed:
Changelog:
Fixed:
- - Mux issue with external trigger
- Mux settling times
- External trigger length drop
- Din clock phase
- Midi clock out lag
- Pattern group bugs in step write and pattern play mode
- Shuffle update in tap mode
- Crash when deleting more than the last track position
- Double midi real time messages on midi out in slave mode
- Various other bugfixes
- (Edit:) OH velocity in tap mode
- - Instruments mute while holding clear
- In tap mode: hold clear + instrument to delete steps
- Seperate CH/OH mute (can be set to combined mute again in global settings page 2)
- Pattern numbers match the step button numbers
- Track and external instrument positions start at 1
- - Performance improvements
- Led flickering
- External instrument midi out lag
Excellent work man!
Amazing. Well done!
zabox firmware Nava_v1_026 available here
Pretty nice job you made. Thank you very much
Really, well done!
Please, check midi play mode, more bugs in hi-hats section, also in tap mode hi-hats work bad this has been repeatedly mentioned below .... thx! great work!!!
I forgot to mention in the changelog that i also fixed tap mode for OH (tapping OH resulted in a low velocity step with dim leds).
OH only cuts when you press it near a CH step.
I didn't experience any midi play (expander) bugs since v1.025. Make sure the sequencer isn't running when using the nava like that. Either set nava as master or better don't send a midi clock at all. Maybe i'll program a special low latency expander mode in the future, but ultimately it's limited to the rather slow midi baud rate. (latency is already <500us)Grizzlydj wrote:Please, check midi play mode, more bugs in hi-hats section, also in tap mode hi-hats work bad this has been repeatedly mentioned below .... thx! great work!!!
Great job !
Would you consider a way to assign custom notes to instruments for the "expander mode", similar to Yocto 1 ?
