BUG: DinSync lags
Posted: Jul 22nd, '17, 08:03
by comboy
The DinSync output lags behind the normal timing.
You can measure it if you compare it to the trigger output or other sounds on a scope.
All synced devices are running a bit behind the NAVA :(
Re: BUG: DinSync lags
Posted: Jul 22nd, '17, 08:38
by KlangGenerator
Maybe Vincent should hire you as his software developer... I'm pretty sure you could push things forward quickly... ;)
Posted: Jul 22nd, '17, 09:42
by comboy
sadly I don't really have the time at the moment... too many open projects.
Posted: Jun 7th, '18, 17:13
by zabox
Fixed in v1.026 ;)
Posted: Jun 7th, '18, 18:09
by tekno808
zabox wrote:Fixed in v1.026 ;)
Great job zabox !
Posted: Jul 22nd, '20, 16:57
by Dr.Knob
Have you noticed that if nava is master it transmits dinsync. If nava is expander it does not transmit dinsync. Okay so far that's not surprising. But if nava is slave it transmits crappy dinsync. I would say about four times slower...
Posted: Dec 12th, '23, 02:41
by farare
The lag seems to occur consistently, and it affects various aspects of the system, making it challenging to enjoy a seamless experience. Whether it's delays in synchronization or disruptions in the overall responsiveness, these issues have become a notable hindrance.
Geometry Dash
Posted: Jan 16th, '24, 19:41
by Oortone
farare wrote: Dec 12th, '23, 02:41 The lag seems to occur consistently, and it affects various aspects of the system, making it challenging to enjoy a seamless experience. Whether it's delays in synchronization or disruptions in the overall responsiveness, these issues have become a notable hindrance.
Geometry Dash
Hello, I'm looking into the firmware but will probably not touch low level stuff like sync. However with the newly released pre beta I posted in another thread I did some tetsting syncing my TR606 from Nava using DIN sync. In general I get a lag perhaps 1 out of 5 starts, seems random. The other starts are in sync and stays in sync.
Although it might not be random but instead depend on where in the main loop of the whole firmware the start is pressed. If that's the case I might be able to fix it.
What do you mean by "affects various aspects of the system".
