Is the external Instrument been implemented yet? The manual says to press 'instrument select & guide" to enter the external Instrument edit page but this doesn't work for me. I can select "ext inst" and program the trigs but but note value, length and octave doesn't exist.
I think the HH trigs need working on. The way the OH dosent rule over the CH and each part when programmed will delete the other isnt correct functioning. For example the classic swooshing OH then the CH added on the 16ths, the oh trigs will be deleted and not sound when they should rule. If I'm jamming this is essential.
Also... FLAM
Thanks
External Instrument and HH trigs
serum114,serum114 wrote:Is the external Instrument been implemented yet? The manual says to press 'instrument select & guide" to enter the external Instrument edit page but this doesn't work for me. I can select "ext inst" and program the trigs but but note value, length and octave doesn't exist.
Also... FLAM
Thanks
To edit EXT instrument note: Select EXT instrument by pressing "instrSlct + Guide" then press "Num". Use Steps button to enter notes.
About the HH: As OH and CH sound share the same generator (Eprom) you can not trig both together, as made the original TR909.
