Midi bug in v1.019: Closed HH changes to Open HH.
		When sending midi from my DAW, closed HH (note #42) changes to open HH if there is another drum (with a note number over 42) on the same step. Try this: make a closed HH pattern in a DAW, add mid tom on the same step, now open HH is triggered. Drums with lower note number than 42 doesn't affect the HH. Internal patterns on Nava works fine.Last edited by Peter on Aug 28th, '16, 11:19, edited 3 times in total.
Same bug/problem here.
				I experience it too, it seems that if there's only a CH playing it's fine, but when the CH is played at the same time as the BD, the OH plays too.
edit: when MIDI is only sent to CH and OH it works well but when other instruments (I noticed it with the SD) are involved it interferes with the OH.
Dear Diyer,
CH/OH bug fixed in midi play
Add synced pattern change
viewtopic.php?f=25&t=864&p=4853#p4853
