Accent trouble HH/Ride/Crash
  • Hmm that's a weird problem. Do you know anything about the history of this particular machine? Did it work before and suddenly was damaged like it is now or did the failure appear gradually, e.g. first HH, then Ride etc..?
    When it comes up to problems like this where the failure is only on the digital instruments but all of them, you would search for a circuit part which is shared by all these instruments. Unfortunately the digital instruments are quite well separated here. All of them have their dedicated oscillator for clocking the ROM-output, their dedicated DA-converter which is simple R2R-resistor ladder, dedicated envelopes and so on. But it's possible that opamps or logic gate ICs might be shared by the instruments, because one IC often contains several logic gates like NANDs or Flip Flops. Unfortunately there's only IC58 (4520, part of the address counter for the ROM) which is shared by Crash and Ride.
    But Crash and Ride share the DA-converter for Accent (volume). Generally if the Accend DA-converter fails, the instrument will most likely produce no sound, because Accent will be 0V.
    A failure of the CPU is rather unlikely because it just creates the trigger and accent data for the instruments and for the CPU it doesn't matter if there is an analog or digital voice being played.
    Do you have any electronics experience and lab equipment like oscilloscope?
    The general procedure for your type of errors would be:
    1. Check oscillators of HH, Crash, Ride if they output approx 60kHz square wave (which is then divided by 2 by the followed clock Divider which gives you approx 30kHz sample rate)
    2. Check if Trig and Accent (which is actually always present and setting the volume as mentioned above, it just has different values between 0-5V) are present at all instruments.
    3. Check if ROMs are outputting data when triggered.
    4. Check envelopes signals driving the VCA after triggering. Note that HiHat and Crash/Ride use different envelope concepts. Hihat uses a normal analog envelope (two different time constants for Open and Closed HH). Crash and Ride use an additional DA-converter for creating the envelope. So the envelope of the sample itself is used as an envelope to drive the VCA. This is used because these instruments can be tuned, thus making the envelope automatically shorter or longer depending on the tune-setting. THis ensures that the whole sample is being played and not being cut off by a constant envelope. Quite cool concept.
  • Easily set up your Vizio Smart TV or soundbar by visiting vizio.com/setup and follow simple on-screen instructions to connect your device.
    Go to vizio.com/setup to activate and configure your Vizio Smart TV or soundbar for the best streaming and entertainment experience.
    Visit vizio.com/setup to quickly connect, register, and personalize your Vizio Smart TV or home entertainment system.
    Set up your Vizio device online through vizio.com/setup. Activate your TV or soundbar and enjoy high-quality streaming with smart features at your fingertips.
    Set up and activate your Vizio Smart TV at vizio.com/setup in just minutes.
  • Visit vizio.com/setup for a simple and guided setup process. Whether it’s a Smart TV or soundbar, get connected in minutes and start watching.
    Easily configure your Vizio device online at vizio.com/setup
    At vizio.com/setup, you can register and set up your Vizio device quickly. Enjoy seamless entertainment with access to built-in apps, movies, and shows.
    Easily configure your Vizio Smart TV or home theater system at vizio.com/setup. Connect your device, activate smart features, and enjoy unlimited streaming.
    Quickly link your Vizio TV or soundbar at vizio.com/setup.
  • Go to vizio.com/setup to complete your Vizio device setup easily.
    Head over to vizio.com/setup to activate and connect your Vizio Smart TV or soundbar. Follow easy step-by-step instructions to unlock smart apps and streaming.
    Complete your Vizio TV setup at vizio.com/setup and start streaming instantly.
    vizio.com/setup makes it easy to connect your Smart TV or soundbar.
    Activate your Vizio device in minutes with vizio.com/setup.
  • Seamlessly set up your Vizio home entertainment system at vizio.com/setup
    Go to vizio.com/setup for quick activation and device registration.
    Set up Vizio SmartCast devices easily at vizio.com/setup
    Enjoy hassle-free setup for your Vizio TV at vizio.com/setup
    Set up your Vizio Smart TV or soundbar easily at vizio.com/setup.
  • Visit vizio.com/setup to quickly connect your Vizio Smart TV or soundbar. Follow guided instructions to register your device and enjoy endless streaming.
    At vizio.com/setup, you can set up, activate, and personalize your Vizio Smart TV or soundbar. Unlock access to apps, streaming services, and smart features.
    Easily configure your Vizio entertainment system at vizio.com/setup. From Wi-Fi connection to app activation, complete your setup in just a few clicks.
    vizio.com/setup helps you get your Smart TV or soundbar ready for use. Start enjoying your favorite shows, apps, and movies with a seamless setup process.
    Go to vizio.com/setup to register and activate your device. Whether it’s a TV or soundbar, enjoy fast setup and premium entertainment at home.
  • Set up your Vizio SmartCast TV or soundbar online at vizio.com/setup. Connect, register, and begin streaming with smart features designed for you.
    Activate and enjoy your Vizio Smart TV at vizio.com/setup.
    vizio.com/setup – the easiest way to connect your Smart TV or soundbar.
    Start streaming in minutes by setting up your Vizio device at vizio.com/setup.
    Visit vizio.com/setup to unlock apps and features on your Vizio TV.
  • Step-by-step guide to restore your Vizio TV at vizio.com/setup to factory defaults for smooth performance.
    Troubleshoot at vizio.com/setup why your Vizio Smart TV won’t turn on with quick fixes, expert tips, and simple steps to get it working again.
    Easily activate your Vizio Smart TV with vizio.com/setup. Connect to Wi-Fi, register your device, and start enjoying smart apps and entertainment instantly.
    Visit vizio.com/setup to personalize and configure your Vizio device. Whether it’s a Smart TV or soundbar, you’ll be ready to stream in just minutes.
    Make your Vizio setup simple at vizio.com/setup. Whether connecting a TV or soundbar, follow the quick guide to start streaming right away.
  • vizio.com/setup provides a quick way to set up and register your device. Activate your SmartCast TV or soundbar and access built-in apps, movies, and shows.
    Go to vizio.com/setup to easily connect and activate your Vizio Smart TV or soundbar. Complete setup in just a few steps and enjoy unlimited streaming.
    Set up your Vizio entertainment system online at vizio.com/setup. From Wi-Fi connection to SmartCast activation, everything is made simple and hassle-free.
    vizio.com/setup helps you link your TV to Wi-Fi and streaming apps instantly.
