External sequencing NAVA Extra9
Postby Charles Scorsese » Jun 27th, '20, 11:25
I want my nava to behave like a sound module and to be able to sequence its sounds in my DAW. I just want this: sequence the sounds individually.
I know that NAVA has the General MIDI protocol and I want to take advantage of this possibility. In my Roland TR909 it is very easy to sequence your sounds via MIDI, but in my NAVA that is impossible.
Any kind person can explain the combination of buttons that I have to press to have my Extra9 in mode: sound module?
Thanks.
Charles Scorsese
Re: External sequencing NAVA Extra9
Postby m4d » Jun 28th, '20, 23:16
Hey Charles,
The 1.028 firmware has a mode called Expander Mode for triggering the voices by external midi input. Here is some info from the firmware page:
Code: Select all
How to use expander mode:
   - Set sync to "EXP" to enter expander mode
   - Press "Guide" to show triggers
   - Press "Mute" to enter mute mode
   - Press "Bank" to enter gate mode and select instruments like in mute mode
         (gate cuts the sound at a midi note off message)
Cheers,
Chris
m4d
Postby Charles Scorsese » Jun 29th, '20, 22:07
Hi Chris.
Thanks for your help but I don't understand anything. I don't know if I have to press the SHIFT button or the ENTER button or the TEMPO button that capture can't help me...
Charles Scorsese
Postby m4d » Jul 1st, '20, 02:11
Hey Charles,
sorry for not making it more clear. Like i wrote in the Facebook Group:
Code: Select all
Press <SHIFT> + <TEMPO> to enter settings.
Use the <DATA> encoder to set Syn to EXP.
Press <SHIFT> + <TEMPO> two times to leave settings.
The screen should now read "Expander".
Cheers!
m4d
Postby Charles Scorsese » Jul 1st, '20, 13:40
Many thanks.
I appreciate your help, you are very kind.
Charles Scorsese
Postby Charles Scorsese » Jul 8th, '20, 09:04
Hi guys.
I managed to play the sounds of my NAVA Extra9 with my Cubase (with a controller keyboard).
My Extra9's MIDI works very well.
Thank you Klang Generator for building a perfect Extra9.
Charles Scorsese
Postby m4d » Jul 10th, '20, 10:29
Charles Scorsese wrote:My Extra9's MIDI works very well.
Great! :D
m4d
Postby Charles Scorsese » Jul 10th, '20, 10:30
Thanks! :-)
Charles Scorsese
Return to Nava Software
