Nava
Re: Nava
Postby Altitude » May 12th, '16, 13:44
The link to the board file does not seem to work. That's invaluable for building
Altitude
Re: Nava
Postby e-licktronic » May 12th, '16, 19:11
Altitude wrote:The link to the board file does not seem to work. That's invaluable for building
Solved ;)
Site Admin
Re: Nava
Postby southpole » May 13th, '16, 13:38
Solved ;)
no schematics this time? they were quite invaluable for debugging my yocto build...
southpole
Re: Nava
Postby AonFluX » May 15th, '16, 13:28
As I have started to build the kit, I have a question.
In the build-tutorial it is stated that C89 in the bassdrum sect. should be 0.047 microF, but on the picture of the build in the same tutorial, there is a 0.47 microF on place C89 (which is concistent with the schematic I believe).
Anyone that could shed some light on this? Just a misprint in the tutorial?
AonFluX
Re: Nava
Postby e-licktronic » May 15th, '16, 14:50
AonFluX wrote:As I have started to build the kit, I have a question.
C89 is 47nF.
Site Admin
Re: Nava
Postby AonFluX » May 16th, '16, 06:27
Ok, thanks for the fast answer!
AonFluX
Re: Nava
Postby drifter7508 » May 16th, '16, 13:16
Any spec./recommendations for buying the right crimp tool for making the cabels for the molex connectors?
drifter7508
Re: Nava
Postby Patrick » May 16th, '16, 20:40
Why not using MTA156 mouser: 640445-5 with
571-3-640426-5 , its easy to solder cables in, its the same like 4 Pole Headers of MOTM Modularsystems
Patrick
Re: Nava
Postby drifter7508 » May 17th, '16, 10:28
Alla connectors and stuff are allready included in tbe bom. Just need to buy the right tool for crimping these...
drifter7508
Re: Nava
Postby talos » May 18th, '16, 03:32
Hi everyone,
I have a question to ask, but I feel it might be a bit silly. I only soldered the LED's off of the TR-8 here: https://www.youtube.com/watch?v=DCW9T15mBp0
And I figured that after learning to do such a difficult task that I can take on this Nava project. My only issue is that the Mouser parts are so many and I can't figure out which part goes where. I looked at the BRD file, but I'm not sure how to make it tell me what kind of resistor or capacitor a location on the board needs. I received a lot of different capacitors and resistors. I don't want to make a mistake. Is there a way that the Eagle program can tell me for example which kind of capacitor C129 takes? I don't know if it's like a 4700PF 100Volts 5% Film capacitor or 100volts .015uF 10% capacitor.
Sorry again if I'm coming off as a beginner, but I just don't know which parts go where.
Any help is appreciated!
EDIT: Nevermind! I read a little further down and the tutorial for parts begins at the bottom of the page. That helps :)
talos
PreviousNext
Return to Nava Hardware
Users browsing this forum: No registered users and 6 guests
