Nava Sequence won't advance.
I turn it on and hit start, but the sequencer won't advance.
I've reflowed the IC a few times and have reprogrammed it a few times, but no change.
I have built two Navas. One is perfect. One has all of its voices perfect, but not the sequencer. I turn it on and hit start, but the sequencer won't advance. It plays all drum sounds at once and then stops.
I can play all voices via midi.
For some reason pattern is defaulting/overwriting to length of 256, scl of 0, and all instruments on accent high for each step.
So while I am programming a pattern it will suddenly become length of 256, scl of 0, and all instruments on accent high for each step. Patterns are not saving properly.
If I program last step to 16, it will be after the 16th step when it resets.
-Check that EEprom is well powered.AbeLovesSynths wrote:For some reason pattern is defaulting/overwriting to length of 256, scl of 0, and all instruments on accent high for each step.
-Check R689 R690 Resistor value on the I2C bus. Should be 4K7
-Check that they are well connected to +5V
-Try to replace your EEprom
I swapped the EEprom with the one from my working Nava and nothing changed.e-licktronic wrote:-Check that EEprom is well powered.AbeLovesSynths wrote:For some reason pattern is defaulting/overwriting to length of 256, scl of 0, and all instruments on accent high for each step.
I put the EEprom from the Bad Nava into the working Nava and it works just fine.
R689 and 690 confirmed to be 4K7
EEprom gets 4.91 on pin 10 and 4.9 on pin 30
Try to swap your working uC with the one on the Nava that doesn't
I did that:e-licktronic wrote:Try to swap your working uC with the one on the Nava that doesn't
So it's not the EEprom right?
Here is a video showing the swapping of EEproms
What you swap it is the microcontroller Atmega1284p what you need to swap is the small DIP8 I2C EEprom IC115 not IC119AbeLovesSynths wrote:I did that:e-licktronic wrote:Try to swap your working uC with the one on the Nava that doesn't
Ok my bad. Apologoes for not knowing the difference.e-licktronic wrote:What you swap it is the microcontroller Atmega1284p what you need to swap is the small DIP8 I2C EEprom IC115 not IC119AbeLovesSynths wrote:I did that:e-licktronic wrote:Try to swap your working uC with the one on the Nava that doesn't
Swapping did change things. The EEprom 115 from the working Nava, when inserted into the non working one, causes it to work.
So I need to buy a new IC? It is getting ~5V on pin 8.
I've reprogrammed it many times to no avail.
