Hi all,
I have a strange behaviour of the crash on my newly build nava.
When I play the crash alone no issue, when I play it alongside other instruments it has no decay, it is stopped when other trigger.
Here is an audio sample
Please share if you have an idea of the issue
Cheers
Crash affected by other instruments
OK I add 10nF to C6 on each muxboard, re init the eeprom and it seems to be OK but the behavior is the same only with handclap now...
EDIT : Add 10nF parallel to C5 on IC111, re init the eeprom and all is working as expected !!!
